Starter problem PLEASE HELP!!!
Old 02-21-2011 | 01:10 PM
swapsun's Avatar
I recently swaped my 1980 280zx motor into my 1982 due to better body and the 1982 didnt run. everything is ready and hooked up and the starter doesn't work? wtf. battery is fully charged, fuel pump, gages, ect... all working. I went and had it tested, it works, and it worked when it came out with the 1980 motor. Any ideas
Old 02-21-2011 | 01:54 PM
Boostless's Avatar
check to see if your cables and connections are clean and tight. Is it not doing anything at all? no clicking or spinning noises?
Old 04-07-2011 | 07:52 PM
zstuff's Avatar
start?
hello so if you have aportable starter like mechanis push button the starter should work , did you plugin little wire to starter from ignition at back of starter?
Old 04-07-2011 | 11:12 PM
AKZX's Avatar
Have you gone out with a multimeter to see where there's power getting to the starter, if there is any? Just because the battery is good doesn't mean the power is going everywhere.
albertom8819
04-20-2013 07:04 AM
Esc8p2NeverLand
04-11-2010 11:11 PM
Switchtr3
02-20-2010 10:38 AM
User395
02-03-2009 04:15 PM
ZDriver85
05-14-2005 01:21 AM
