Starter Wires HELP!!!!!!!!!!!
Old 12-08-2006 | 04:08 PM
DGriffin's Avatar
Ok So As I Was Figuring Out The Wiring On That "idk What It Is Thing" I Gave A Group A Wires A Little Tug To See If They Were Stuck However The 2 Starter Wires Were In The Group And The Previous Owners Half A** Job The Wires Were Barley Connected And Not Even Properly!!!!
Ok So Im Trying To Figure Out Where These 2 Black Starter Wires Go? To The Ecu? The Big Cable Of Wire That Goes To The Passenger Side? Ive Been Looking But I Cant Figure Out Where They Went Because They Were Just Stuck End To End And Held With Electrical Tape!!!
Please Help I Cant Start My Car!!!
Old 12-08-2006 | 05:00 PM
skittle's Avatar
Taste My Rainbow
Old 12-08-2006 | 05:10 PM
DGriffin's Avatar
Sorry, I Use My Coworkers Digital Camera And Im Off Work For The Weekend. Why Do You Need Pics Tho Im Just Asking What And Where The 2 Black Wires Coming From The Starter N The Engine Bay Attach To Once Inside The Car Throught The Grommet On The Firewall???
Old 12-08-2006 | 05:11 PM
skittle's Avatar
Taste My Rainbow
one goes to a ground usually to the batterytray, the other i'm not sure maybe the chts?? bleach, nismo, Z-gods help this young lad with his question!!!
Old 12-08-2006 | 05:14 PM
DGriffin's Avatar
GROUND AT THE BATTERY TRAY? IM ASKING WHERE THEY CONNECT ONCE INSIDE THE CAR.
AND THX FOR SUMMONING THE Z-CAR GODS. HAHA
Old 12-08-2006 | 05:22 PM
jfairladyz's Avatar
I wasn't aware there were two ground wires coming off of the starter. The starter grounds through the engine. There should be a positive cable going to the starter as well as a small Y wire which is to power on the solenoid. Thats it for the starter. You may also have a negative battery cable that runs to the starters mounting bolt, but that would be it. There are two ground wires that screw to the side of the block near the starter however. So you might check there. Otherwise, yes, we need pics.
Old 12-08-2006 | 05:29 PM
DGriffin's Avatar
Idk If They Are 2 Grounds Coming Off The Starter Or What, Ill Try To Get Pics Asap.
I Was Taking About The 2 Black Wires Connecting To The Starter And Then Go Inside The Car???
EDIT: I JUST CHECKED AND I FOUND THE 2 WIRES COMING OFF THE STARTER ONES A GROUND THE OTHER POWERS THE SOLENOID. THEY ARE ATTACHED I JUST NEED TO KNOW WHERE THE OTHER END OF THEM ATTACHES INSIDE THE CAR.
Old 12-08-2006 | 05:43 PM
jfairladyz's Avatar
If you've got ground wires running from the starter into the cabin then thats the work of a PO, not Nissan. I'd be willing to bet somebody just needed to ground something and that seemed like a logical place to do it. You still probably want to find out whats grounding through those wires though. But if it's not factory then we really cant be of any help to you.
But yeah, pics first to make sure they weren't originally connected somewhere other than the starter.
Old 12-08-2006 | 05:46 PM
jfairladyz's Avatar
Oh, and where on the starter are these wires connected? Is it the solenoid or are the going to a mounting bolt? I just jumped to the conclusion they were ground wires because they were black. But if they're running to the solenoid then they could be power wires. If they're running to the battery cable connection on the solenoid then they are constant hot wires. If they're running to the Y spade connected wire then they're only hot during cranking. If they're running to a mounting bolt then they are indeed grounds.
Old 12-09-2006 | 09:22 AM
DGriffin's Avatar
1 wire goes to the solenoid to power it.
the 2nd wire goes to a mounting bolt and then splits in 2 directions to other bolts not on the starter.
are the wires they meet up with inside the car the same color? where should i be looking to where they connect?
Old 12-09-2006 | 11:38 AM
DGriffin's Avatar
ok so ive been doing some research online and i think i need to re-phrase my question.
- the wire from the positive batt. terminal to the starter. CONNECTED
- the wire from the negative batt. terminal grounded to the starter. COONECTED
- the wire connected to the starter solenoid is connected and the other end goes throught the grommet in the firewall inside the car where its DISCONNECTED. THIS WIRE GOES SOMEHOW TO THE IGNITION SWITCH VIA THE STARTER RELAY CORRECT??? IF SO WHRE IS THIS RELAY???
- and lastely there is a wire that idk what it is but it follows the previously mentioned wire inside. it looks as if it a sensor for the oil possibly??? But i dont think i need this wire connected to start the car right??? just the wire going to the ignition switch???
Old 12-09-2006 | 11:52 AM
wreckedj30's Avatar
No Club Love
i think it must of been done by the previous owner, cause mine only has one to the solenoid, there are some wires from a box next to the battery to the positive trerminal tho.
Old 12-09-2006 | 11:55 AM
DGriffin's Avatar
the one to the solenoid from the ignition???
Old 12-09-2006 | 12:09 PM
wreckedj30's Avatar
No Club Love
it goes to a little box next to the battery don't it. cause i only have two theat go to the starter, pos. and neg. to the battery.
Old 12-09-2006 | 01:03 PM
DGriffin's Avatar
WHEN I ACCIDENTALLY PULLED IT OUT OF PLACE IT WAS GOING INSIDE THE CAR THROUGHT THE FIREWALL. DOESNT IT HAVE TO SOMEHOW REACH THE IGNITION OR STARTER RELAY??? OR DID SOMEONE HOT WIRE IT KINDA???
Old 12-09-2006 | 01:15 PM
wreckedj30's Avatar
No Club Love
i'd say they hot wired it. Cause i only have the two battery wires to the starter. The other wires to the pos. battery terminal come from a little box next to the battery..don't know, nismo should be around in a few minutes, when you say his name three times, he appears its kind of cool...like the candy man or tu pac!
Old 12-09-2006 | 02:08 PM
DGriffin's Avatar
haha nismopick, nismopick, nismopick
yeah i have the wires that your taking about hooked up but im talking about the 1 going to the ignition so when you turn the key it turns on the starter.
Old 12-09-2006 | 02:26 PM
wreckedj30's Avatar
No Club Love
hmm, i don't no, i don't have anything else from the starter, do you have the box i'm talking of? Someone hella smart should stop by. Sooner than later.
Old 12-09-2006 | 02:31 PM
DGriffin's Avatar
yeah i have that i think relay box your taking about and everything seems to be hooked up correctly in and to that. but i have another connection on the solenoid right near where the pos batt. connects to, and that connection next to the poss batt one runs a wire to the other side of the engine and throught the firewall and then im stumped as to where it goes, because it wasnt connected right last time so its just a cut wire on that end.
Old 12-09-2006 | 06:54 PM
DGriffin's Avatar
Ok I Figured Out The Problem And The Car Starts!!!!!!!!!!!!! Idk Exactly What I Did Yet But As Soon As I Figure It All Out Ill Reply With What The Prob Was. Thx For All The Help Well Kinda!!! Haha Jk
Old 12-09-2006 | 07:42 PM
So I've been out all day, and D got the prob fixed... whew! Without pics it's hard sometimes to see what wires are in question.
Old 12-10-2006 | 10:37 AM
DGriffin's Avatar
Yeah In The Future Ill Make Sure Ill Get Pics (getting A Camera For Christmas). I Did Some Research About It And It Prolly Woulda Been Hard For You Guys To Help Me Because It Turns Out It Was A PO Thing. Thanks For Your Time And Trying To Help Tho I Really Appreciate It.
sepulvedajoseph
01-09-2014 04:05 PM
El_Colombiano
01-18-2013 03:36 PM
Superduner
06-23-2006 08:36 AM
AlongCamePeter
09-12-2004 06:20 PM
ZWINTERZ
11-06-2003 03:21 AM
Quick Reply: Starter Wires HELP!!!!!!!!!!!
