swapping cams
Old 05-24-2012 | 02:12 PM
Kerias's Avatar
swapping cams
i know this subject is probably been talked about but i hear that my 82 280zx N/A has the "good head" and the crappy dished pistons and crappy intake? am i right? either way i hear there are different cams that went in to this same motor changing them every few years and from what i have heard is that the A series camshaft is the one to get? what kind of power increase am i looking at with this camshaft? any advice is appreciated
Old 05-24-2012 | 02:19 PM
Dunno where you "heard" all this...
I'm pretty sure they didn't use the low compression "dished" pistons for the n/a after 77 or 78... you should have flat tops. There are various cams, but the A cam change is for the turbo.
Where are you reading this info?
Search our forums and Google for the L-Series engine and cam specs. I have those links at home, but I'm at work, and you should be able to find them online in about 30 seconds.
Old 05-24-2012 | 02:20 PM
10 seconds actually...
http://atlanticz.ca/zclub/techtips/cam/index.htm
Old 05-24-2012 | 03:48 PM
Kerias's Avatar
so my stock 82 has flat top pistons? so my CR is 9:1ish? regardless what would be a cheap good power adder?
Old 05-24-2012 | 04:15 PM
https://www.zdriver.com/forums/280zx...2-280zx-32759/
https://www.zdriver.com/forums/280zx...d-200-a-32526/
https://www.zdriver.com/forums/280zx...suprise-30962/
https://www.zdriver.com/forums/280zx...2-280zx-30343/
Old 05-24-2012 | 07:45 PM
The only time I'd consider swaping in a stock cam is putting an "A" grind from a NA into a turbo head...
Ratfink
21
07-22-2014 12:48 AM
zcrazy13
08-19-2011 01:02 PM
NateB
04-19-2006 11:40 PM
rebello240z
01-29-2005 06:23 PM
Lazerus
10-29-2003 02:03 PM
Quick Reply: swapping cams
