Thermostat housing problem
you can try tapping it off with a hammer to loosen it off the broken bolts or you can remove the lower section of the thermostat housing that has all the sensors. it bolts up to the head with 2 bolts i believe. after that you can try to disassemble it on the bench and try taking off the broken bolts with a pair of vise grips.
Turbo Biscuit
11-24-2012 06:33 AM
