Timing
Old 04-08-2005 | 06:39 AM
DoTheDrew888's Avatar
Timing
The timing can be changed by the position the cam gear is set at, right? This changes the position of the timing chain and the cam timing, correct? So my question is, How do I know where to set the cam gear? I have an aftermarket cam so this will effect the timing.
Old 04-08-2005 | 08:39 AM
EatmyDust's Avatar
The cam should be the same prety much. #1 cyl TDC #1 int. lobe TDC. I am close to posotiv on this. the key on the crank should line up with the notch on the cam.
Old 04-08-2005 | 04:33 PM
So what about my ignition timing? Will I have to play with that in order to make maximum power?
Old 04-08-2005 | 10:16 PM
duckyz's Avatar
Yes...abooultely. I don't know where you need to have it since I don't know what kind of cam you have.
Old 04-09-2005 | 09:08 PM
Here is my setup and cam specs:
-N47 Head *Port and polish / valve job*
-Schneider Race Cam (MSA Stage III)
-Flattop Pistons (9.8:1 Compression)
-Centerforce Dual Friction Clutch
-CAI
-3 into 2 Headers
-2.5" Pipes
-High Flow Cat
-Dynomax Ultra Flo Muffler
Cam: Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280
Any suggestions? Is this the type of thing where I can just adjust it by ear or should I use my timing light?
Old 04-09-2005 | 10:30 PM
duckyz's Avatar
I'd start at -10* TDC (someone correct me if I'm wrong, please!!). See how it runs, take it for a good spin around the block. Make sure that your RPM's are staying around 900-ish at idle and that the idle is strong..not racing...a good strong idle.
That's what I'd do, but opinions differ.
Old 04-10-2005 | 01:12 AM
EatmyDust's Avatar
just pop your hood, and loosen the bolt on your distributor, and turn it slowly back and forth and hit the throtle linkage between each move, and leav it were it soots you. you might end up turning it and leaving it to your left if you like fast take off, but that is advanced I think.
sidneyam
02-21-2011 05:51 PM
Datsun_Husky
11-17-2010 05:48 AM
Fast240Z
05-25-2005 11:13 PM
crazytvrguy280
03-27-2005 08:39 PM
Zmedic
07-20-2001 01:26 PM
Quick Reply: Timing
