timing and oil pump
timing and oil pump
Is it true if your l28 is at TDC and rabbit ears are up o 1 cylinder that your timing chain is correct regardless of marks?
Part two how does and oil pump change timing and distributer?
My y question please any respnce is grateful.
Yes in a properly timed, running engine, if you do the TDC on compression stroke the chain marks don't have to line up.
Oil pump doesn't change timing or have anything to do with it. The marks are there just so you can line it up easier for "insertion", and initial setup.
Did you see this?
https://www.zdriver.com/forums/280zx...p-guide-40948/
Shows how to properly align distributor and oil pump shaft.
sameerb1
03-20-2011 05:21 AM
z32convertible
01-08-2011 11:05 PM
ern
10-20-2006 07:01 AM
