tranny problems
Old 10-24-2005 | 08:15 AM
gabrielzzz's Avatar
tranny problems
well i just replaced my alternator, and now the engine is running great, ive been completely satisfied with everything mechanical that has gone wrong because i have been able to fix it all myself, and yesterday i just bearly made it into my driveway and my clutch pedal goes completely to the floor with no pressure at all...really bummed out, i checked the fluid lever, and it was topped out, im thinking either i just need a new clutch cylinder or i just need to drain the gunky fluid out, because the fluid looked almost black...any other opinions??
Old 10-24-2005 | 08:29 AM
it's not a "tranny problem," it's a clutch cylinder prob... yes, if the fluid is black & gunky... you SHOULD prolly bleed it you prolly have air in the line too, which will keep the petal from popping back out. Bleed the line w/ new clear brake fluid & you'll be fine.
Old 10-24-2005 | 08:30 AM
icice9's Avatar
Super Siver & Black Stud
clutch master or slave cylinder... but before you go and change them out you might want to change your hydrolic fluid and bleed your system.. if that dont work.. then id prolly replace the master cylinder first...
Old 10-24-2005 | 08:48 AM
gabrielzzz's Avatar
sounds good, thanks for the help
Old 10-24-2005 | 09:10 AM
Carl's Z's Avatar
As cheap as masters and slaves are, I'd just go ahead and change them out. Easy, quick job and cheap...
Old 10-24-2005 | 12:36 PM
gabrielzzz's Avatar
anyone happen to have a slave cylinder?? or a master, but im pretty sure the master is ok
Old 10-24-2005 | 01:15 PM
RodMoyes's Avatar
Doesn't post much...
Don't buy used ones. You can buy new or remanufactured ones from any auto parts store pretty cheap. Do it right the first time and you won't have to do it twice...
Rod.
Old 10-24-2005 | 01:35 PM
Rod.
wait a minute! u trying to tell me that I shouldn't get a junk yard one w/ 200k miles on it?
Old 10-24-2005 | 01:50 PM
I just threw away my new slave cylinder for one off a 270K mile parts car! DOH!
Old 10-24-2005 | 02:53 PM
gabrielzzz's Avatar
Rod.
HAHA, I LEARNED THAT AFTER I JUST REBUILT MY ALTERNATOR, DIED 2 WEEKS LATER...JUST BOUGHT A NEW ONE FROM BOSCH
Old 10-24-2005 | 04:18 PM
People still rebuild their own alternators? I thought that was almost illegal these days!
Old 10-25-2005 | 08:17 AM
gabrielzzz's Avatar
illegal??? i dunno, if there is a law against fixing my own car for cheap, then thats bull $hit
Old 10-25-2005 | 08:18 AM
gabrielzzz's Avatar
oh, and also, thanx for the tips everybody, i just bled my clutch fluid and bout a new slave cylinder for 20 bucks, now it works better then ever =-)
Old 10-25-2005 | 09:47 AM
I wasn't serious about being "illegal" .... it's just pointless to me to rebuild it for $40, or buy a new one w/ a waranty for $60.
Old 10-25-2005 | 10:59 PM
jfairladyz's Avatar
It's always a good idea to replace the slave and master cylinders as a pair. Even if only one is the cause of the problem.
And hell, I rebuild anything I can get the parts to rebuild it with. The only time I don't rebuild something is if I'm in an emergency. I just rebuilt my rear calipers (one was siezed but I decided to rebuild both) and now those are working great. If you can buy something rebuilt, then you can rebuild it yourself. That's of course considering that it's not worn or damaged beyond repair.
Old 10-26-2005 | 01:26 PM
gabrielzzz's Avatar
yea...at the time my alternator was out, i was pretty low on cash, so at the time it saved me money until i got my next paycheck, so rebuilding it was the best option
Old 10-26-2005 | 01:27 PM
gabrielzzz's Avatar
oh, and to jfairladyz, nice colors for that Z, im thinking the same thing, except gold and a black stripe
Old 10-26-2005 | 09:05 PM
jfairladyz's Avatar
Gratsi (or whatever ). A lot of labor went into getting that body where it is and it's nowhere near finished. That was just a quick paint job cause I was moving and had to get the metal covered up . I still got plenty to do to her.
lemitless300zx
05-05-2011 02:32 PM
nismaniac
07-23-2006 10:30 AM
LittleblueZ
05-16-2006 12:52 AM
'76Z
01-28-2004 06:23 PM
GOMEZGOGO
12-04-2003 12:31 PM
Quick Reply: tranny problems
