Turbo Factory Vs Turbo Aftermarket
Old 08-28-2003 | 09:38 AM
If you suspect that your country did not get the factory turbo Z, then you may be right. 5/80 is a little too early for the 1981 280ZX turbo. In fact, I think they were produced part way through 1981, probably mostly preorders.
Some other distinctions are the distributor; the Nissan turbo Z has a much larger diameter distributor cap and a larger diameter Air Flow Meter. You can compare these to your own cars as I see you already have some 280zx's.
HKS is aftermarket. I think the brand of turbo Nissan used is Garrett(?) ...or is that the style of turbo. I haven't owned a turbo Z yet.
Old 08-28-2003 | 10:58 AM
lifegrddude's Avatar
Externally Wastegated
I think it is an aftermarket bolt on, the stock on is like Bleach said a Garrett turbo. If you look at my cardomain page on page 7, you'll see the stock turbo. Another thing to add is that the turbo models of the 280ZX had a different front grill from the naturally aspirated models.
http://www.cardomain.com/id/lifegrddude
John 82ZXT
2.8.0.Z.X
12-28-2007 11:24 PM
motoxracing909
18
01-29-2007 09:23 PM
Turbo86
12-17-2006 12:06 PM
mazda_6t9
01-11-2006 10:11 AM
