update on the Superturbo (m90 and t3/4) header is on
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
The header and the turbo mounted on my mock up engine
the header itself with the bung for the EGT
I will use my internal waste gate for now as it should be sufficient for the boost the turbo will run.
If not at least the engine will be in the bay so i can see where i have space left as it is getting cramped!
Its coated now, so all i need to do now is heatwrap it.
Next project is the plenum for the ITBS but that is well on its way
nice work frank, who built your turbo header, that one looks to be the utmost quality!!! i was trying to get a m90 super for one of my projects, but money has now gotten in the way, those are simple and easy to mount to!!
Euro Z King
The header was started by someone and i found it in CA. (no flange some tubes unfinished etc)
Then i cut it up agian as the welds looked like .. well ****, rewelded it and finished it up, got it coated and that is about it.
I could have sand down the welds but that doesn't make it stronger.. besides it will be heat wrapped aswel.
your a fab master!!!
and idk if you saw my last comment in your other thread, but i asked if you'd be willing to re-create that super setup (just the fab work like the mounts, pully setup and the flanges with piping you got as pictured) if so, at what price $$$$ cause id be really interested. and final question, exactly what S/C is that? other than an eaton lol
Euro Z King
i would not be feasible to reproduce this, to time consuming and not worth the effort, i'm sorry.
Besides i own a IT consulting firm that is time consuming as is. Note that im willing to provide detailed pictures on request
Euro Z King
No i haven't really decided on the exact clocking. Ill either go over or under the engine to the SC im getting the plenum fabbed up now then ill see as like this it wont clear the plenum
unless you wanna change your mind....
or if some one here wants to take his offer on the pics and manufacture a batch set and sell them. that would be smart. i would do it, but like i said, no way even possible for me to do that.
