Webbing Removed
Webbing Removed
Has Anyone Taken The Webbing Out Of There Intake Manifold, Kinda Like Some N42's Ive Seen Out There.(s/c's Photos Got Me Thinkin Again) I Was Wondering If It Helps Cool Each Runner, Or Is It Even Worth It. It Would Make It Easier Access To The Header Bolts Though
Originally Posted by Skully
the webbing is suppose to dispurse heat and take it away from the intake runners...
Yeah I dont think that webbing is doing anything but hindering the dissipation of heat. The heat has no where to go but sink into the intake manifold with the webbing there. With the webbing gone the heat can pass right through and vent through the hood. Leaving a fin on either side of each runner though would help with the dissipation for a little while. Once that aluminum gets so hot though it doesn't matter cause it can only dissipate so much heat. Also, it might be a good idea to leave some sort of webbing in there to support the runners. You'll notice on the early manifolds without the webbing there is still a little near where it attaches to the head. I think the webbing is just there for ease of casting. The casting mold probably lasted longer by leaving the webbing in there. Where as with just casting the runners individually complicated the sand mold and probably didn't last as long. It's most likely just a case of what was cheaper for Nissan. I'm sure they went to the non webbed manifold temporarily cause it ran cooler, but ended up not being worth the cost.
Two problems with the water mister idea:
1. The water runs out
2. You'd have to pour a boat load of water on there to dissipate enough heat to make a difference
Then you're only using the intake manifold as a heat sink to transfer the heat from the exhaust manifold to the water.
You're still better off with a header blanket and open intake runners.
Ideally, header wrap in addition to the open intake runners, but the wrap will collect moisture and rust your headers into oblivion in almost no time so a header blanket is a reasonable compromise.
This will let any heat that escapes the blanket flow around the intake runners and exit the hood. A nice functional cowl induction hood with a high CFM fan would complete the puzzle.
C&R sells a 3400 CFM fan that will fit our cars...
If I still have heat problems with my ZXT, that'll be the next step.
Cloging Of Tools Would Not Be A Problem For Me Nismo, The Proper Tools (ones Made For Aluminum Dont Clog) And A Product Called Boe-lube Really Helps Lube The Tools. And If You Cant Guess Its Made By The Boeing Aircraft Company In Bleaches Home Town. Ive Worked On Aircraft For Years And Love Aluminum To Death, You Just Need Special Cutting Wheels Called "green Corps" And Zing Out It Comes. Ill Post Pics When Done Later. Thanks For The Feedback Guys
If you need one to expeirement on, let me know. I have a extra 1 you can practice on.
Oh, and if your thinking of doing it and selling em, Please put me on the list of potential buyers. Depending on price and other stuff of course. Thank you
I think if he gives you one for free to experiment on and even ships it to you free, it would be neighborly of you to give it back to him at the same price once you've perfected the process...
Lost, you never sent me your shipping address for the euro mirrors... You still want 'em?
Hey I Started On Removing The Webbing, The Stupid Egr Casting Is On The Bottom, So All The Webbing From The Top Side View Cant Be Removed. But It Is Going Well. Ill Post Some Pics Here Soon.
Originally Posted by lww
EGR?! We don' need no stinkin' EGR!
. This disclaimer brought to you by friends of L-Dub... A not-for-profit organization.
Rod.
Originally Posted by RodMoyes
Of course, Grand Master L-Dub is in no way condoning the removal of any device that may interfere with the vehicles emmisions system or any modification that may result in emmisions being greater than the vehicle manufacturer inteneded or beyond legal limitations for said emmisions. Doing so is the sole responsibility of the vehicle owner and is subject to the laws of the state of residence for the operator of the vehicle.
Rod.
Rod.
Originally Posted by SHADY280
Problem Is If It Gets Ground Off, Then There Are Holes In The Manifold Making A Vaccum Leak, A Really Big One.
Of course, you should only do this if it's allowable based on your local city, state and Federal guidelines...
Rod, you kill me!
