Weird Reving Prob.
Old 01-31-2005 | 07:16 PM
Weird Reving Prob.
My 79 Has This Weird Reving Problem That Exists Only When The Engine Enters Its Normal Operating Temperature Mode. When Driving Only, It Will Rev To About 3000 Rpm. If I Stop The Car Or Go Under About 10kph It Stops Reving.has Anyone Encountered This Problem, Its Really Getting To Me!!
Old 01-31-2005 | 09:02 PM
s/cL3.0's Avatar
Bleach is my Hero
My Z used to shut down completely right when it hit the F.. It was a prob with the ignition module, might want check that out.
Old 02-02-2005 | 07:36 PM
Mine Did That Too, Fixed That, Only Problem Is Mine Isnt Shuting Down It Revs When Driving, Then Idles Only After I Stop
Old 02-02-2005 | 09:46 PM
s/cL3.0's Avatar
Bleach is my Hero
So when your in nuetral coasting it will still rev?? That is strange
Old 02-04-2005 | 07:07 PM
Yep You Got It, And Yeah That Is Strange Im Thinking Thermotime Switch, Speed Sensor, Air Flow,throttle Position, Something Like That, But Im Not Sure Because Ive Tried Testing All Of Them, And They Seem To Be Fine, Hence Me Asking The Forum.
Somebody Please Help!
Old 02-11-2005 | 06:58 PM
Has Anybody Even Got Some Ideas? Please Help
Old 02-21-2005 | 08:26 PM
duckyz's Avatar
Try the old ECU pull & clean. Pull the ECU, clean off the contacts and re-install. Be sure to disconnect the battery first.
Old 02-22-2005 | 08:19 AM
When it is doing the REV thing, if you slap the throttle down and release, will that let the idle drop to normal?
I would first inspect all hoses and connections on and around the throttle body. A vaccume leak makes the most sense. I'm not going to try to guess how it is causing this, but reving usually means more air. More fuel would just bog the idle down.
Old 02-25-2005 | 07:23 PM
If You Rev It While It Is Doing This It Just Continues Revving, All Of My Hoses Are Pretty New But Im Going To Try That It Makes Sense Except For The Fact It Doesnt Do It When It Is In Cold Run Mode. After Msd Sends Me A Wiring Diagram For My Car FOR AN 6a Ingnition Box I Will Be Able To Continue On The Hunt. Thanks Any Input Will Be Helpful
Old 02-26-2005 | 12:28 PM
That is beacause usually when it is cold the engine is revving lower. Especially when your cold start valve does not work. I never could get either one of my Zx's to work. SO when they were cold they were hard to keep running, but once they warmed up they were fine. Usually within a few minutes.
Old 03-03-2005 | 09:36 PM
Tested My Cold Start Circuit And It Works Fine, Doesnt Run At Lower Revs When In Cold Start Mode.
Jennings.brent6
05-31-2014 12:10 AM
Tuners dream
02-20-2013 07:32 AM
FricFrac
11-15-2012 07:39 AM
rgus30
10-29-2006 12:49 PM
87' 300
09-01-2004 05:48 PM
