What is causing it to flood out???
Old 07-03-2003 | 12:25 PM
Do you think that there is a possibility that it is running a bit rich all the time? It might be another sensor or the fuel pressure regulator holding too high of fuel pressure. then, under most driving the throttle position switch tells the computer to run a certiain amount of fuel. At WOT, that percentage jumps up at 20%. Patricla throttle might still run good, just rich, but maybe the WOT command from that switch is causing just too much fuel. I had a simular problem, and it was the fuel pressure regulator. Once that was replaced, everything ran much more lean and I had better power and better gas milage.
If that's not it then maybe the Air Flow Meter is improperly adjusted. Its probably not the throttle position switch itself.
Lesnocker
04-17-2013 11:49 PM
corbith
10-04-2012 07:29 AM
irishdrunk
06-17-2011 11:42 PM
domsgarage
16
04-05-2004 07:37 PM
Carwood
03-06-2002 02:40 PM
