what torque should i torque my turbo head to?
Old 10-08-2005 | 05:26 PM
280zExTURBO's Avatar
what FT/LB's should i torque my turbo head to???
PLEASE help me out. If you have a manual look for me please.
Old 10-08-2005 | 07:45 PM
for all those who look at this and know the answer...thanks for the help...
This site needs a more helping environment.
Old 10-08-2005 | 08:37 PM
Carl's Z's Avatar
If I'm reading the FSM correctly, it's saying 14ft/lbs. Someone here with a little more knowledge should back me or correct me, though...
Old 10-08-2005 | 09:48 PM
14ft/lbs is way too low. Im talking about the head BOLTS not retainers for the camshaft. I learned that the hard way. LOL i striped my head at first.
Old 10-09-2005 | 01:11 AM
Have you thought about buying a Haynes or Chilton manual??? They help a lot, cuz they have all the specs on several pages!
Old 10-09-2005 | 01:13 AM
I believe the specs are 63 - 69 ft/lbs torque for the headbolts... but I don't want to go out to the garage @ 2am to look it up for ya.
Old 10-09-2005 | 10:11 AM
lww's Avatar
lww
Head Muckraker
Dude. You made your first post at 5:26pm and the one above at 7:45pm on the same day. That's a whole 2 hours and 19 minutes before you were upset that there were no responses.
You do realize that people don't sit on this forum anxiously waiting for someone to post a question so they can jump in and answer right?
This is not a 'real-time' communication mechanism. People live in different time zones, have 'jobs' and 'families'.
If you think this board is tough, you should spend some time at ZCar.com or HybridZ.org. You would have been flamed into a charred mass by now.
This is probably the friendliest and most tolerant Z forum out there.
You've asked half a dozen questions that could easily have been answered with a $15 Haynes manual from your local auto parts store or about 10 minutes of searching this forum. If you had spent that 2 hours and 19 minutes researching, you would have discovered the answer on your own and wouldn't have had to get frustrated by our lack of 'customer' service skills.
For the record:
Tighten the two center (right & left) head bolts to 14 ft/lbs.
Install the camshaft sprocket together with the timing chain onto the camshaft. Make sure that the marks you made on earlier disassembly line up. If the chain will not stretch over the sprocket, you've let the tensioner fall out and you'll have to remove the front timing cover to put it back in place.
Once you have all the head bolts in finger tight, tighten them down in the following order (looking at the engine from the driver side fender):
(12)(8)(4)(2)(6)(10)(14)
(11)(7)(3)(1)(5)(9)(13)
If you tighten them out of sequence, you will put torsional stress on the head that will prevent a proper seal of the head gasket and can warp the head.
You should make THREE passes to tighten the head bolts.
First Pass: 30 ft/lbs
Second Pass: 44 ft/lbs
Third Pass: 60 ft/lbs
If you tighten them down to 60 ft/lbs on the first pass, they will not properly seat and it will put torsional stress on the head that will prevent a proper seal of the head gasket and can ultimately warp the head.
Old 10-09-2005 | 08:45 PM
im sorry for rusing. thanks
Old 10-09-2005 | 09:13 PM
lww's Avatar
lww
Head Muckraker
For future reference. Never buy someone else's half finished project. It's a 1000 times more difficult to put it back together when you weren't there to take it apart.
Good luck.
kittyz
09-25-2009 10:53 AM
xchristheisx
09-19-2006 06:17 PM
PeteZ Racing
01-20-2006 08:55 AM
bbotts
12-08-2002 04:28 PM
mck2
08-15-2002 11:24 PM
Quick Reply: what torque should i torque my turbo head to?
