wierd fuel pump question
alright guys, this is a wierd one, my fuel pump used to come ON and stay ON as soon as i turned the key to the ON position, then just the other day, it didnt run, i was kinda worried. i listened and listened and couldnt hear it. its kinda loud cause its a high performance after market pump. so when i turn the key to START, and start the car, it runs and keeps going as per normal, what would cause this to happen. im wondering if one of the relays is bad, or if it isnt getting a signal from one of the sensors, but isnt keeping the pump from running. any ideas appreciated, cause its probly something stupid
I doubt it's the relay cause then it wouldn't work even when the car is running. After you let go of the key it goes back to 'ON' anyways. What year is the motor and wiring on it? The later years had the one relay controlled by the ECU. The earlier ones had 2-3 relays controlled by different things. Get under the dash and test to see if the relay is getting power while the key is 'ON' but the engine is not running.
coffenbacher
04-22-2012 02:46 PM
