Z31 Ecu
Guest
Posts: n/a
Z31 Ecu
I just bought a Z31 N/A MAF for my L28E, now all I need is the ECU
Whats involved in switching over to the Z31 ECU?
PS, is there anyway of making sure that the MAF actually works(i.e isnt damaged) ?
Guest
Posts: n/a
It might be easier to swap out the circuit boards from your 83 into you Z31 AFM. In order to change ECU,s you will have a lot of wire tracing to do. The Z31 has a lot more electrical crap to worry about. The 83ZX ECU is pretty simple to play with. I know when swichting to a Turbo AFM from an 81-83ZX to a 1st gen Z you have to swap out the board.
I hope this helps you.
