Z31T ecu swap now complete!
#26
Originally Posted by nismo619
Hey nismopick did u write down all the stuff u needed and a step by step " how to " u know what i meen if u did can u post it ? or send me it.. i have a huge alot of z cars i can find and get partz off of.. 240z 260z 280z 280zx's turbos 300z-31's and z32's there is a place in " Amarillo Texas called " ALL ABOUT JAPANESE " auto recking they have every single z car i could dream off i went there this weekened .
Here's where I got all my info:
The Z31 ecu swap guide:
http://forums.hybridz.org/showthread.php?t=91250
Another similar guide (less helpful for me, but talks about diff ecu options):
http://www.freewebs.com/1971datsun24...0Injection.htm
And Lifegrddude's SAFC thread:
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/z31-setup-w-safc-17290/
RIGHT CLICK & SAVE AS:
EDIT (5/6/09): Link no longer active. You can download the file via ZDriver attachment: https://www.zdriver.com/forums/attac...9&d=1238179990
#29
Wahoo!!! I finished the Z31T ecu swap into my 280ZXT today. Holy sheet it made one hell of a difference!!! I decided to do this as my Z would lean out REALLY bad at mid to full throttle.
#35
Originally Posted by EatmyDust
so no one has stuck the cone filter directly on the afm? I think I am going to find a way to make room and do it. the only thing is that wouldn't that kind of blow the afm out of wack? I mean it is an air density thing right, and if it is coming through a restriction that close to a vain, how could it get an acurate reading?
The stock air box with a K&N is probably better off then the CAI's you see on ebay. Right now I'm building an aluminum box for my CAI. My Z had a CAI on it when I bought it so thats the route I'm going.
#36
#37
I eventually do this to all my inline nissans whether N/A or not because all are expected to wear a turbo at some point.
Of course, the map on the later z31 ecus is better than a spring so it's a no brainer.
Best to do the swap alone and not when you decide to change a bunch of other stuff so you can troubleshoot it more easily.
#38
There are several changes that must be done to do the Z31T ecu swap.
#1: VG30 distributor chopper wheel (optical crank angle sensor disc) must be used in place of the 280zxt one. It has a larger hole at TDC for better timing & fuel control.
#39
Originally Posted by Heat Rave R
So when getting the Z31 chopper wheel at the junkyard, should I grab the whole distributor assembly, or do I only need the innards?
EDIT: here's a pic:
#41
ok, so I haven't been able to do anything to the car for the past month, since it's been a mixture of snow, rain, and down *** coldness... but it was warm today so I started back at it... got everything wired up except for the ignition coil. I am confused as to which wires go where. on the excel spreadsheet nismopick posted, it says that ECU pin #3 goes to the original (-) coil wire, and pin #34 goes to the (+) coil wire. However, I don't see anywhere on the wiring diagrams where the wires for the coil originate. This is the only thing I have left to do before I can attempt to start her up and see if she explodes or not.
Any insight?
Any insight?
#42
#34 is the same thing: Add pin to 280zx wiring harness: attach to + ignition source I may have updated my Excel spreadsheet since I put together that zip file, but it should say almost the same thing.
Anyway, you add a pin to the 280zxt ecu plug #34 & run the wire to a + ignition source. The black with white striped wire for the fuel pump module works great.
Last edited by NismoPick; 02-05-2007 at 07:06 PM. Reason: Forgott'd some bolding :D
jmmorriso
10-29-2007 06:51 AM
