1982 280zx Turbo
1982 280zx Turbo
Hey guys!
I figured I might as well run this car by you for some insight, can't hurt.
I'm looking into buying a 1982 Nissan 280zx Turbo. I'll give you what the craigslist add says in a nutshell.
Hey I have a 1982 Nissan/Datsun 280ZX Turbo with a completely rebuilt engine using OEM Nissan parts with only 11K on it.
The interior is in really really good condition for the year, no tears in the seats or anything!
She has t-tops and they don't leak.
Body is strait.
5-speed stick (Borg-Warner)
Custom limited slip differential
Upgraded brakes
Upgraded suspension
Upgraded turbo (T04B)
Upgraded control system (Z31 Turbo)
Greddy Profec B
The car does NOT pass SMOG. I have fixed a exaughst leak on the turbo since smogging her but, no garuntees that fixes it.
The E-brake could use a new cable, the current one is stretched to far, but still works in a pinch.
Needs a new starter, still push-starts though. Once the car is started it will NEVER die on you.
Car was built by a Nissan/Datsun Z series enthusiast whom I bought it from, drove for around 1.5K miles then decided it just wasn't for me. Also, car is not currently registered. Has not been registered for about 5 months now.
(This makes me think these forums have seen this car before, if you recognize it let me know!)
Some Pics:
After talking to the guy I have realized he's not super technically inclined, and doesn't know a ton about the car. He's asking 2k for it, I'm going down to go take a look at it tomorrow.
What do you guys think?
Body is strait.
Upgraded brakes
Upgraded suspension
Greddy Profec B
Some Pics:
$2k for a modified 280zxt is usually a good deal (as long as the mods were done correctly).
Are those the craigslist pics? If they are (the most recent) then I have some concerns for you to check tomorrow:
#1: The "brake upgrade" can only be pads since the stock swastikas are still on the car.
#2: The AAC valve is still on the intake (it's usually removed for the Z31T ecu upgrade).
#3: You better double check that it REALLY does have LSD. Lift the rear end & spin one tire in the air, the other tire should spin the same way. If it spins the other way, or doesn't spin, it does NOT have LSD.
#4: Check the struts & springs... if they are "performance" they will be colored. Stock is black w/ no logos.
#5: Hopefully you can identify the differences between the stock T3 and a T04B or T3/T4 hybrid.
Thanks for the help Nismo!
Edit: Never mind, figured everything out. Just one thing though, what benefit does a z31 ecu have over the stock 280zxt ecu?
http://www.nistune.com/equipment-products-type1.php
You can now view and log RPM, Speed, MAF voltage, O2 sensor, Temperature, Battery, Timing and various switch settings. Diagnostic Terminal Codes can monitored and cleared. You can also perform real time tuning with this board!
This board along with the NIStune software provides consult capabilities (including Diagnostic reporting) and map tracing for non-consult Nissan ECUs
Thanks for the info DevilZ
An update on the car, I went and checked it out today and everything looked good. Car ran great, and everything checked out. A few little things need to replaced and cleaned but aside from what was said in his original post nothing huge. I'm getting it for $1800
Hopefully I'll be picking it up this weekend and I am sure all of you will see some pictures not long after that! And of course mechanical updates (And many questions I'm sure haha) will come too.
Yes I definitely did, the front and read shocks were aftermarket, struts were stock. The odo reads 79k miles, but the engine is pretty much new at 11k miles. The ecu was a z31 ecu. Brakes were pretty good, but needed to be cleaned and possibly the right side pads replaced. It has an LSD and the interior is in prime condition considering the age.
I am pretty much in love with this car at the moment, gotta get a few things replaced, pass smog, and register it. Then it'll be my DD
Sorry haha. I have my terminology really wrong, like I said, new to all of this stuff.
I meant the tension rod I believe. But yeah, shocks and struts are aftermarket. What kind, I have no clue. They were light blue though.
Another note, the car is a 2+2! I wasn't expecting that but it's kinda nice actually. I thought I was just going to have to deal with two seats.
Edit: I am actually currently trying to get in contact with the original owner of this car who did all of the work on it. The story is that he retrieved the car from a junkyard with no engine, and put one in after rebuilding it himself. But we'll find out when he responds to me!
Welcome to the club..... even if it is a 2+2 ;P
I came across the photo album of this car's rebuild online and it all looks fantastic. I honestly can't believe I just picked this up for only $1800. If anyone is interested I'd be more than happy to post it up here for you guys. If you could just tell me the easiest way to do so that is. There are about 107+ pictures and they're organized into a few separate folders.
Sounds like it:
Yep... the first year (81) 280zxt only came as a 2seater auto, in 82-83 it was available as a 2+2 & BW T5 manual trans options. There's even a pic of an 82-83 280zxt 2+2 in the front of the Haynes manual. The beauty of S30's / S130's is the ease and availability of part swapping.
Here is the album! I uploaded it to photobucket. The pictures are a little backwards as far as order goes though unfortunately.
http://s1085.photobucket.com/albums/...rla/?start=all
Apparently the story from the guy I was buying it off of was a little wrong. From what I can tell in the pictures the car came stock as a turbo. It's got all the decals, and all of the parts for one. Not to mention the cool "turbo 280zx" writing on the taillights
And yes they are Tokico.
Here, I've got a little list from an ad he had of the specs.
Originally Posted by Ebay Ad
About the Car
This is my 1982 280ZX Turbo. I've had her for a number of years now, and I've decided that I would really like to reinvest, and focus more on my 1967 Roadster.
This car is registered, running, and currently my daily driver.
The body has 248,000 miles.
The engine, suspension, brakes, and everything else has about 8,000.
History of the Car
I bought this car in Oakland as a long-term project in 2007 - with a salvage title. It remains unclear how it got the salvage title, but since the driver side lock was drilled out when I got it (fixed now), I've been assuming theft recovery.
I've had no trouble with registration or insurance.
The engine is completely rebuilt with OEM Nissan parts, properly broken in, and about to hit 8,000 miles.
Upgrades and Restoration
I tried very hard to remain true to the original spirit of the car, and make tasteful modifications that didn't depart from the stock design.
Engine
2.8L Fuel Injected, Turbocharged Inline-6
Completely rebuilt using OEM Nissan parts
Decked and refreshed P90 cylinder head
New water pump & thermostat
High Volume oil pump
New distributor
New alternator
New engine mounts
New fuel injectors
New 3-Core aluminum radiator
Electronics
Z31 Turbo computer upgrade
Z31 Turbo MAF upgrade (no more AFM!)
(Rare) Greddy Profec B Spec I boost controller
(Rare) 1979 120mph speedometer
Turbo & Exhaust
Garrett T04B "H" Trim Compressor
Water cooled center section
"Stage 1" Turbine wheel
Tuned for 10psi
Catalytic converter delete (for off-road use only, of course!)
New Magnaflow straight-through muffler
Drivetrain
Low-mileage Borg-Warner T-5 (5 speed)
New clutch
New flywheel
Limited slip differential (Custom built helical-type)
New differential mount (I guarantee you NO ONE ELSE has replaced this)
Brakes and Suspension
Rebuilt master cylinder
New Cross drilled and slotted rotors
New Ceramic pads
Rebuilt calipers
Falken Ziex 912 tires (215 front, 225 rear)
Cosmetics & Rust
This is a California car, and has nearly zero rust. There is a little bit on the edges of the battery tray, but none anywhere else (including the spare tire well, edges of the hatch, and undercarriage).
The paint on the hood is coming off, and will need to be redone in the near future.
There is some past body work on the passenger fender that isn't noticeable until you're looking for it.
Front leather seats are freshly reupholstered.
New headliner.
New rear trim.
New floor mats.
Two hairline cracks in the dash
Picking it up tomorrow hopefully! Unfortunately though, the kid who owns it at the moment might have screwed me on paperwork. I don't think he ever turned in his bill of sale to the DMV, and I doubt the got the title given over to him either. Luckily I have good contact with the original owner if that's necessary, but I have a feeling this might be a bit off a mess to figure out.
If all goes well though, I'll have that car back at my place tomorrow afternoon! I'm planning on picking up a starter on my way home. Anyone have any guides on how to replace it, or pics of where it is or anything?
I'll be searching right now but any information you can throw at me (Tips etc) will be very helpful.
Congrats on the car. Once you've got the paper work mess worked out you've got a nice setup for a great price. I was looking at S130's here on the East coast in Halifax and they want an insane amount of money for theirs - $7500 for a NA... crazy...
