1982 280zxt. Acceleration problems over 4500 rpm
Old 06-25-2002 | 12:29 PM
Re: 1982 280zxt. Acceleration problems over 4500 rpm
True, I would guess that the injectors got clogged. You know how some carb's needles go bad from fuel drying in them for long periods of time? Well, the same can happen with old injectors. They can loose their efficency, especially at idle. You may now need to run cleaner in them or replace them. Your air over the cylinder might only be the intake/exhaust gasket as opposed to your head gasket. (if you're lucky)
Replace all the tune-up stuff and run some cleaner in your gas tank. Maybe open up the throttle position sensor and use some electrical contact cleaner on it. Then drive the car easy for a while and see if it gets better. Don't forget the fuel pressure regulator and oxygen sensor go bad with time too. Those are fairly cheap and easy to replace.
Old 06-30-2002 | 11:44 AM
zguy36's Avatar
Dead
check your AFM. if it is dirty, then you will have that problem
evandubya
01-06-2015 08:04 PM
GNRick
07-30-2014 02:26 AM
Tonybologna69
12-02-2012 06:29 PM
gabrielzzz
18
03-20-2006 11:19 AM
gabrielzzz
08-23-2005 08:39 PM
