1983 280zx turbo problem starting and running possibly fuel
i recently put a new heater core in my car and every since it has had problems running. its like it is flooding itself trying to start and when it does start it runs fine until i change gears or stop itslike any time i let off the gas it has a problem getting back its pressure.
You disconnected something when you did the heater core. Either electrical or vacuum. Probably vacuum since you were in hte climate control system. Generally if it was working and now doesn't it is the last thing you changed.
I agree about the possibility of disconnecting something. I had a similar problem and found the plug on the side of the engine above the starter was disconnected. Once I put it back it was running like a bat out of Hell. I recommend you check all the plugs (some look like they are connected, but may be loose.). Good luck and have a happy holidays. Sincerely Dan
what an idiot
well i honestly deserve the idiot of the year award!!!! i checked the CHTS vacuum lines and all connectors. then low and behold decided to check the spark plugs. well they were shot, bought 6 new ones changes them in 5 minutes(the beauty of an inline) and magic running like a bat out of hell again. thanks to all who gave me there feedback and opinions.
jrlogan280z
05-08-2010 08:23 AM
