1983 280zxt checked everything still no spark
Old 01-27-2015 | 07:46 PM
murdockshady's Avatar
Unhappy 1983 280zxt checked everything still no spark
so i had a hard start issue about a month ago. and since then have replaced cas, coil twice. done the hei igniter conversion , changed ignition switch and still no spark. coil gets 12 v but no spark. have fuel and afm is working. 0.04 volts from yellow igniter wire . dont know if thats correct v range or not. new plugs wires cap and rotor. ecu has green light on except when turning over ignition it turns off until i turn key off and then back on ,then it relights until trying to start again. i am at my wits end with this car. i was excited to have my very own z and this happens. any help will be much apreciated.
Old 01-27-2015 | 07:48 PM
also yellow wire does not pulse
Old 01-27-2015 | 11:53 PM
borini63's Avatar
Is your Fuel Pump works good?!?!
Old 01-28-2015 | 08:24 AM
If the ecu is getting power and there's no power (pulse) on the yellow coil wire, you have a dead ecu. I have a spare dead turbo ecu that does the exact same thing. Somebody on the 280ZX Driver FB group mentioned that it's the "zero-ohm link / resistor" in the ecu, and they fixed this problem by replacing that resistor. I've never researched it, but that's a start for you.
And, if you need to replace the ecu, now is a perfect time to do the Z31T ecu / maf upgrade (I have a helpful zip file of info, and I have most of the needed parts).
Old 01-28-2015 | 06:33 PM
thank you
i'll research that. does anyone have an idea of where on the board i can find it ?
oh and yes it does have fuel. the relay cuts on and off so often that i put it on a switch.
Old 01-28-2015 | 06:36 PM
NismoPick . Are your items for sale or your own collection for a upgrade ?
masterhufflpuff
07-22-2015 08:05 PM
rhythm
01-13-2013 08:48 PM
Bernardd
02-07-2011 01:04 PM
Adam87
06-01-2010 08:13 AM
mikep
02-28-2009 04:54 PM
