280ZX Slugish Acceleration
Old 06-26-2010 | 06:04 AM
Sgonzo's Avatar
My 83 280ZX (non turbo) response to throttle inputs is sluggish. It's not horrible bad, but just not as peppy. I saw some improvement after cleaning corroded injector connectors but still not quite right. However, occasionally when the stars align and I get a brief (5 to 10 seconds) burst of Z acceleration and it feels great. I am due for spark plugs, distrubutor cap and wires but have never replaced the O2 sensor.
Appreciat the help!
Steve g
Old 06-26-2010 | 10:06 AM
Welcome to ZDriver!
What's the timing set to?
Old 06-27-2010 | 07:55 AM
Sgonzo's Avatar
Timing is set at 8.
When I really step on the gas the car hesitates and then it grabs and I get good acceleration. Maybe fuel filter or pump?
Thanks.
Old 06-28-2010 | 08:06 PM
vrocious's Avatar
vacuum lines? when mine came off it was a pig to accelerate, especially when cold
Old 06-29-2010 | 08:48 AM
njgheewala's Avatar
Dunkin' Donutz
Welcome to Zdriver...When mine had issue I had the Air Flow Meter issue. Got someone who was an expert at it and got it adjusted properly and it is working like a charm. It takes of like a rocket. I think there is a HOW TO here to do it your self.
Old 06-29-2010 | 10:42 AM
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/js-how-rebuild-your-afm-15277/
http://www.kamikazeracing.org/dl/JsAFMRebuild/
Here is the how to rebuild your AFM from a sticky thread. Good luck.
Old 07-02-2010 | 10:10 AM
Sgonzo's Avatar
Thanks for all the ideas. I am ashamed to admit my spark plugs were in dire need of replacement and they were pretty bad. The sluggishness is gone, I replaced ignition wires, distributor, rotor and plugs.
The only snag left is a stuck transmission filler plug. (I removed the transmission to change the rear main oil seal and clutch) Can't get the plug off and have pretty much destroyed the original plug. I gave up and used the reverse switch opening to fill the xmission.
I may wait for cooler weather and attempt to remove the plug -
Thanks for the help!
Steve g
Kevdogg
06-23-2014 10:53 AM
ksloan25
06-02-2010 12:02 AM
maalsa
01-21-2009 08:26 PM
drftrzx
10-08-2008 10:07 AM
pconno4
05-02-2006 07:16 PM
