280zxt idles when cold wont idle when warmed up ??
Has a fairly recent plugs , wires and dist cap Nismo.. was idling fine even after warmed up til recently.. fuel pressure is about 50 Roger.. chts?? Will continue to look for a vac leak ! THANKS !! Has EGR valve got anything to do with idle?
I agree to check the CHTS, if you don't know what that is look up the FSM and find it in there (Cylinder Head Temperature Sensor - should be on the passenger side of the block under the 5th and 6th spark plug I think).
Does the car not start again until it's cooled down? A bad Ignition Control Module can cause issues that are similar.
Also now that I am rethinking this you want to be checking all of the major sensors (AFM etc). More info would be really great.
Are you saying it won't run at all once it warms up, or it just won't idle. How does it drive once warm if it does drive?
Air regulator, AFM, CHTS, and/or ignitor as everyone has previously mentioned. Also the AAC valve (aids the turbo model idle).
Check them... do it... do it...
If you haven't done so yet, I highly suggest downloading the FSM for free from www.xenons130.com/reference
One of the best things you can do right now. Is pull the connectors, and with a toothbrush and WD-40 clean all the connectors, let them air dry and put them back on. And see if that helps if not. then just use process of elimination. It is fun trust me, been there done that. lol But do what Nismo said, and download the FSM. Quite handy in a pinch, good luck.
If you haven't done so yet, I highly suggest downloading the FSM for free from XenonS130 - S130 Reference
ZX-Turbo idles and then dies
You said your fuel pressure is about 50..... what did you measure it with? S-30 and S-130 z car fuel pressure is only approx 37.1, so if you really have 50 it's out of spec and you should be balling smoke out of your exhaust. 50 is definitely out of specs.
mcge8241
06-18-2019 02:47 PM
