81 280zxt w/ z31 ecu maf issues
Ok i worked on my 81 zxturbo with z31 ecu maf.. when floored it goes to 3-4k and starts poping like Fireworks but if i accel slowly it goes all the way to 5-6k.. when it pops gauge shows rich mixture.. rechecked valve adjustment replaced rotor cap.. it seams like its not getting enough air or spark.. black smokes comes out.. need help
This was discussed on FB... not sure if he fixed it yet, but on Jarom's car that I've been working on it was a combination of 3 things:
-Camshaft sprocket was 1 tooth off
-Distributor shaft was 1 tooth off
-Faulty CAS in the distributor
Fixed the timing and replaced the CAS with one from a Z31 and it runs great.
I know datsun280zxt (Guillermo) didn't have the timing mark plate attached to the timing cover, so he couldn't even check the timing. He said he was going to reinstall it.
81turbocoupetx
12-19-2012 02:56 PM
