82 280Z Won't run.
82 280Z Won't run.
Car was running fine, changed radiator. Had engine running, water in new radiator,waiting for engine to warm up. Engine died, tried restarting it. Would start, run for about 5 seconds then die. Engine would immediately die if I pressed on gas pedal. All fusible links look good. Don't have a LED to test the injectors. Fuel filter/fuel pump tests ok. Praying that the ECU isn't dead. Is there a standard fuze to protect it?
Welcome to ZDriver!
An engine needs 3 things to run:
-Air
-Fuel
-Spark
The engine is probably either starved for fuel or flooded. Usually when this happens right after replacing something, it's because a sensor or connector got knocked loose.
So... first things first: Check AFM & connection, CHTS & connection, fuel injector connections, check to make sure the fuel pump is priming.
BTW... if it's an 82, it's a 280ZX not a 280Z. I will move this to the proper section.
-Air
-Fuel
-Spark
My money is on: "Got water/coolant in the AFM plug while monkeying around with replacing the radiator".
Check the plug on the top of your Air Flow Meter. If it's wet, you must acquit! I mean.. er... If it's wet, that's your problem.
Happens all the time.
