82 280zx: Idle Problem
Old 08-13-2013 | 09:50 PM
Crusty_Lips's Avatar
Hey guys, I am a noob FYI... I have a problem with my Z. It Idles rough and misfires a lot. It idles like its on a urge of stalling. When I give it gas it revs like **** then dies. I replaced the spark plugs and wires and its still the same. I have a feeling its my fuel pump. I did hear a lot whining noises and and humming noises all the time prior to this situation. Can a bad fuel pump cause my car to idle and act up like this? Couple days before all of this I did notice loss of power and the car felt different. I was scared that I had some weak cylinders but when I tested them all cylinders had good compression, so Im guessing it should be an air or fuel problem. Any info will help.. Please and Thanks
Old 08-14-2013 | 08:20 AM
The fuel pump is external inline, so it will always be louder than an in-tank pump like on most cars these days. But if you suspect the fuel pump, check the fuel pressure.
Also check:
TPS
CHTS
AFM
and timing
fanglord
06-08-2014 10:02 PM
Z Pal
02-27-2014 09:50 PM
motormark
06-20-2012 07:10 PM
nismodrifterx
08-19-2011 04:37 PM
deckart
11-27-2002 05:20 AM
Quick Reply: 82 280zx: Idle Problem
