83 280zx non t Fried ECU?
Old 09-26-2013 | 03:45 PM
mixon123's Avatar
close mr
Old 09-26-2013 | 05:53 PM
mixon123's Avatar
One more thing...I pulled the ECU and turned the key to the "ON" position and the fuel pump worked right, stays on for 3-5 seconds and turns off. So I started the car without the ECU and it does the thing, except the fuel pump will now shut off when turn the key to the off, take it out.
mixon123
Old 09-28-2013 | 12:55 PM
Twiggs280zx's Avatar
I upgraded to the GM 1 Wire and had to run a power wire to the alt.
There should be a ground from the battery to the body then starter. One power to the starter. Make sure the wires on the alt are hooked up right.
Silvershade255
02-24-2014 06:37 PM
Zer0Tolerance26
07-31-2013 04:23 PM
Schultzy
11-06-2012 02:51 PM
HybridS130
08-31-2006 06:42 PM
91Zman
06-12-2006 01:00 PM
