83 power steering
well i was contemplating taking the power steering off b/c of a leak and to save jus a lil bit of weight i know it isnt much but i was talking about the actual ps rack and pinion cuz its got a lot of play in the wheel turning to the left
You'd lose a grand total of prolly 6 to 7 lbs... not enough to make up for nightmare turns below 10mph (keeping the stock rack). Is the leak coming from a hose? Connection? Reservoir? Rack? Boots?
Have you checked the ball joints?
its a hose in a couple places...i actually took the belt off of a nissan p/u i had with 31s o nit and i drove that for a couple months and it was pretty tough i jus didnt know if it would be as bad since the tires are way smaller
just replace the how its easy. you can even try some stop leak, it works if its a small leak usually. but i would do something fast cause if you keep runing the pump out of fluid or low on fluid it will die
shall345
01-04-2004 03:10 PM
