about to clean the bay...
hey... quick question.. im about to pressure wash my engin bay.... what do i have to do before i clean it?? like on the sensor and stuff.. theres the rubber thing covering the wires, there crack and i can see the wires on some of them... what should i do? and will anyhting happen if i wash it like this?
https://www.zdriver.com/forums/280zx-s130-forums-77/wierd-engine-problem-17948/
don't spray the distrib, tps, or afm.
u know what i do ? i buy a can of engine degressor and use a tooth brush of all things and with the engine off and cool i spreay it on the intake manafold all around and i scrub off all the grim and stuff then i do the same to the side of the egnien block were the spark plugs are... i cant stand my engine a little bit dirty .....
if you have a lot of grease use something called "gunk" it will clean it up real good. just make sure you cover up all the electronic stuff... I did that all i did was disconnect all the electronics and labeled them bundled it up, wrapped it in saran wrap and covered the dizzy with a plastic bag. then sprayed the gunk on it let it soak for about 10 mins or so then power washed it off... the bay is sooo cleacn you can literally eat off of it...
oh yeah and to clean out your engine and fuel system get a can of "Sea Foam" and put it in your gas tank and in your engine where you add the oil. let it run for about 10-15 mins at idle and that will clean out the"gunk" inside your engine as well. not to worry you might see blue exhaust come out but thats ok its just the sea foam..
yeah the acid is always good as long as you don't let it stay on the rubber hoses and what not... we don't need any melted rubber all over the bay... if you decide to use the acid dilute it well. and remember kids stay off of the acid... lol
