Accessory Relay?
Old 02-14-2011 | 02:31 PM
BackHouseZ's Avatar
Accessory Relay?
If Anybody knows what the Accessory Relay controls please tell me?
Old 02-14-2011 | 02:33 PM
I'm going to take a stab in the dark and say it controls the accessories.
Old 02-14-2011 | 02:47 PM
BackHouseZ's Avatar
i'm just curious which ones. my dome lights dont work nor does my power mirrors.
Old 02-14-2011 | 03:07 PM
icice9's Avatar
Super Siver & Black Stud
when your turn your ignition to ACC... everything that turns on im guessin.. like the radio. cig lighter etc...
Old 02-14-2011 | 04:08 PM
Have you checked the fuses?
All relay and wiring schematics are found in the downloadable FSM here: www.xenons130.com/reference
Old 02-15-2011 | 08:04 PM
BackHouseZ's Avatar
I checked fuse. The Service Manual says its the first one from the top on the left side. Should be rated at 10A. Also I checked fusible links
Old 02-15-2011 | 08:20 PM
Try your lighting relay. (room lamp timer) On my n/a, it is located on the driver side kick panel area. My dome light didn't work, and I changed out the relay, and it worked after that. Also I replaced the door lock timer relay also. And my power locks worked again.
Old 02-15-2011 | 08:57 PM
BackHouseZ's Avatar
i will look into that..
My door lock only unlocks, lock does not work?
wrenchwench
04-06-2015 03:27 PM
ezramoore
03-31-2007 05:26 PM
malikot
02-23-2007 02:35 PM
Creator
05-31-2004 12:59 PM
leemarshall50
03-13-2002 06:17 AM
Quick Reply: Accessory Relay?
