air intake, need your input
Old 04-05-2014 | 09:27 AM
nick 78132's Avatar
my son and I just purchased a 1980 280z.
He turns 16 in a couple months so we have time to fix it up.
The air filter is crazzzy dirty, so I'm thinking about just adding a cold air intake.
Any suggestions?
Old 04-05-2014 | 09:37 AM
rogerz's Avatar
Grumpy & Helpful
the stock set up is a cold air intake. but a nice new elbow and cone filter looks much cooler. more expensive than changing the filter element. look for cracks in the rubber pieces that connect filter to intake. here are some things to better spend money on:
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
Replace outer tie rod ends, and ball joints. replace the bushings with poly (don't forget to lube them as directed unless you like squeaky things). New shocks. Get new boots for power steering. all those things will make you think you are driving a different car. doing them piece meal is a waste you won't see a great improvement until you do the complete job. You need to get the car realigned after messing with the front. Have your tires in good shape and rebalance. Rear bushings nice too but more work and you won't notice as great an improvement. Rear shocks also because if the fronts are gone so are the rears. if car squats when you jump on the gas the rears are gone. If you have the electro adjustable shocks they are DEFINITELY GONE.
Old 04-06-2014 | 08:32 AM
nick 78132's Avatar
Thank you for the information and valuable input.
We are installing a new battery to day so....
Old 04-06-2014 | 10:28 PM
Just note that if you do replace the bushings with urethane that you don't use the urethane on the TC rods... they often fail with urethane and you will loose steering when they do fail. Not good....
cbaumy34
12-28-2012 07:02 PM
the_journeyman
11-20-2012 01:31 PM
Etherealwolf
10-03-2011 05:36 PM
Code-Red
08-18-2011 06:36 PM
ZXT83
01-10-2010 07:42 PM
Quick Reply: air intake, need your input
