Analog Turbo!?
Analog Turbo!?
Is it even possible to properly build an carbed turbo? (yes Im thinking of the Devil Z) I THINK the Devil Z had triple SUs and twin turbos. I dont even get how you can do that to be honest.
lol yeap i have this
sad part is i bought it and went with a different engine so now it just awaits for someone else. i was going to gut the carbs and drill injector holes so basically it would be individual throttle body setup. but never got around to it. mikuni carbs 40mm
Lots of dune buggy builders use turbo carb setups on VW engines. Relatively simple, but just not quite as tunable as EFI. I did a quick search on google for "weber turbo carb" and got lots of results.
yea you can turbo webbers why these have a all alum plenum attached to them. i would recommend a rebuild and a slight draw back is when it was shipped to me the chock valve housing was broke but they sell all new parts for webbers. yes these are forsale. i paid 550 plus shipping for them and i would take 500 shipped or something reasonable . the cannon intake itself is worth a pretty penny. sorry didnt mean to thread jack
260Zturbo, let me get back to you on that. I still have to get my 240z home first lol
And Nismo, I'll take a quick look. But I like the idea of triple carbs better lol
Ok how on earth would you tune a analog turbo Z???
Depending on how you tune it "normal" varies. Somewhere in the ballpark of 11-14 for a/f ratio
You should read MAXIMUM BOOST. It will definitely give you a good insight on building an old school turbo setup. I have it floating around ZDriver somewhere in pdf form if you feel like reading from your comp screen for hours.
You want to turbo your triple carb'd 240Z? Get this book:
http://www.amazon.com/Maximum-Boost-...5561603&sr=8-1
A draw through turbo is easier, but a blow-through is "better" and can be intercooled, etc.
A draw through turbo is where the carb is "in front" of the turbo, so both the air charge and fuel charge go through the compressor on the turbo. This results in fuel "pooling" at the bottom of the turbo housing. You do get some intercooling effect as the fuel cools the air charge as it's compressed by the turbo.
A blow through, is where the carb is "behind" the turbo. So, the turbo takes the air charge and compresses it before passing through the carb. This allows you to put a conventional intercooler in the system but requires you to make the carbs "pressure proof" which they were never designed to be able to hold boost, in my case 21 psi... :O
I don't have any recent photos since everything was cleaned up and powder coated, but here's my intake, carbs and surge chamber:
Ah ok I didnt know what those terms meant! Thank you Iww. as for max boost in a blow through set up, cant you up the PSI in the carbs to counteract the pressure in the intake system by the turbo?
And Nismo, I wouldnt mind reading it on the PC if its free lol. Or I'll just print it all out in B&W lol
if your interested and wanna work something out just shoot me a email 260zturbo@gmail.com
Carbs are not designed to "hold" a pressurized air charge. They're designed to operate under vacuum from the suction that results from the piston moving down on the intake stroke and that vacuum is considerably less on the negative side of pressure than the boost generated by the turbo, even at moderate levels.
When you put pressure into something that's not designed to be pressurized, it tends to leak that pressure which makes it hard to predict how much fuel you need to mix with an unpredictable amount of air because of the pressure leaks.
One solution is to build a pressure "box" that fully encloses the carb to equalize the pressure outside the carb with the pressure inside the carb.
So, the turbo feeds into the "box" and the carb takes the pressurized air charge from the box that surrounds it. This tends to take up a lot more space and since the intake is on the same side as the exhaust in the L6 motor, that leaves more time for the exhaust heat to heat the excess air charge in the "box" making it even less in addition to creating an unpredictable amount of turbulence as the air charge transitions from the turbo piping to the "box" and again into the carb.
I've seen this done with turbo charged carb'd V8's.
surfacing121
05-12-2004 03:25 PM
