anyone swapped T5 into NA?
Old 06-25-2003 | 12:32 PM
zpeedracer25's Avatar
Hey all,
Just wondering if anyone has swapped the T5 into a NA 280ZX. I have a T5 just laying around and the 240k mile trans in my NA is on the way out. Just wondering if it just bolts in and you use the NA slave cylinder and clutch or if its more involved.
Thanks,
Old 07-10-2003 | 07:59 AM
Re: your t5
Originally posted by z-280zx
yout t5 wont bolt to your n/a couse the drive shafts are differnt and the t5 tail shaft is longer
I know that these parts are different and can be easily remedied with the correct drive shaft and diff flange. I'm concerned more with the clutch and slave cylinder differences.
Old 07-10-2003 | 08:06 AM
Originally posted by burt280zx
which five speed came in the 80 n/a zx?
I believe its what is referred to as the 280b trans. Ratios are as follows: 3.062, 1.858, 1.308, 1.000, 0.773
The synchros are on the way out and the trans is tremendously noisy and I found metal chunks in the fluid at the last fluid change...doh. So, the T5 sound like it would be a decent upgrade and probably less expensive to install then it would cost to rebuild the original.
WeTrippyMane
02-28-2014 03:12 PM
vale2489
04-01-2013 11:07 AM
Z31_john
11-06-2009 07:56 AM
skittle
09-10-2006 01:02 PM
280steveX
06-01-2003 06:27 PM
