Been a while need help with problem...
First start of the am car has lean pop and will no move out of its own way..
unplug chts runs fine until warm then floods the engine.
With that being said checked for corrosion, adjusted idle a little, slightly clamped fuel return to raise pressure no resolve in the issue.
Also replaced chts with oem as well as after market no change. Cold start valve and thermo time switch work perfect, anything else I am missing before condemming ecu?
Thanks
Thanks
So the car runs like complete *** for the first 2 minutes of the day, lean pops and barely moves on its own power. Any ideas.
chts-new
coolant temp-new
thermo time switch-new
cold start injector-new
maf-cleaned
plugs-new
chts-new
coolant temp-new
maf-cleaned
plugs-new
I decided to pull plugs all were fouled EXCEPT for the one with a brand new injector. So I bought an otc fuel injector cleaning kit (the kind that goes through the fuel rail not the manifold gimmick) ran 2 tanks of cleaner through it. Let it sit over night and what a beauty. Runs like a dream and only 278k miles
