Before & After
Before & After
Clean up that engine bay! 12,000 less vacuum hoses, a shiny rail and a bit of buffing and the 280zx head and manifold can actually be seen with the naked eye.
Before:
After:
Before:
After:
I like the motion blur effect that the first before picture has on it. It makes it more dramatic. But it looks cool. I'd like to do that to my turbo, so then that way it's a lot easier to redo vacuum lines, as well as find vacuum leaks, plus it just looks better.
Actually, if it wasn't for my vacuum leak, it would run fine on startup without manually gas pedalling it. I have the idle speed bumped up a bit on the TB.
Electric fan would be good indeed. Will perform that swap soon enough. And I will be using green zip ties to hold it on.
