The Bitter End
Old 07-23-2009, 06:54 PM
  #151
I have actually been thinking that. Some of the Z31 ecu code websites say some codes stay in the ecu. I don't know for how long, but I do disconnect the battery before every diagnostic run. And since I haven't been driving it lately, I keep it disconnected while it's parked.
As of now, the only issue is the hard start.
NismoPick is offline
Old 07-23-2009, 07:26 PM
  #152
bojo68's Avatar
Yep, there's a short term and a long term memory on many of them. The phrase "keep alive memory" comes to mind. I believe disconnecting the battery does NOT erase long term memory. But everey manufacturer is different, and I haven't played with these much.
bojo68 is offline
Old 07-24-2009, 12:10 AM
  #153
Mr. Fancy Connectors
Mhinrichs's Avatar
Hum... what bike is it again?
Today I swapped the lowest ecu connector w/ one from an 87 Z31. The ground pins were toast, and looking at the schematic, those are the grounds for most of the sensors. Well, that fixed the rough idle (idles like a freaking champ), but it's still got the hard start, and the same ecu codes are being displayed.
95 cbr streetfighter, now running a 2004 f4i swingarm and 180 rear tire, f4i suspension.
Mhinrichs is offline
Old 08-27-2009, 09:44 PM
  #154
And the Z is back to life again. Runs great. Still running 8psi boost as the motor has about 470mi on it (I try not to boost...).
Pic of the new Z31 ecu plug (I suggest all 280ZXT owners chop and replace it asap), and updated pic of my engine bay.
Attached Thumbnails The Bitter End-dsc08908-copy.jpg   The Bitter End-dsc08911-copy.jpg
Old 08-27-2009, 09:47 PM
  #155
This facepalm's for you!
skib's Avatar
you haz a cute intercooler
skib is offline
Old 08-27-2009, 09:58 PM
  #156
It's getting bigger real soon like... don't blink...
Old 08-27-2009, 10:03 PM
  #157
aww, such a cute little motor.
hoov100 is offline
Old 08-27-2009, 11:43 PM
  #158
Externally Wastegated
lifegrddude's Avatar
For your code 23, my friend and I had something similar on his 240sx. We extended the ground wire of the tps and grounded it to the chassis as well. Same with the ground for the MAF wire. It made a world of difference in how his car idled. (no more lopes during cold start or stop and go traffic now) Maybe it can help you out as well. Nissans have notoriously crappy ground wires.
lifegrddude is offline
Old 09-01-2009, 01:34 PM
  #159
I'll check my MAF ground. It may not be in the best position. But the TPS? Which wire is ground because there's only 2 on the ZXT & they both go back to the ecu.
Old 09-06-2009, 11:23 AM
  #160
was it just a ground then??? i really want to do this upgrade but z31's arent all the common in the yards, or any older z for that matter.
SHADY280 is offline
Old 09-06-2009, 12:37 PM
  #161
skib's Avatar
soooo... want to re-read that statement and tell me all the flaws in it?
no?
ok well first off, WTF is a speed barrier? and how would gas be free then? that in no way relates to back to the future, and u spelled future furure which sound more like a typo of someone saying ruler in German than an English word. lol.
you just dont understand quantum physics
skib is offline
Old 09-06-2009, 03:20 PM
  #162
Sorry, I was assuming you were using a 240sx tps with your z31 setup. The MAF ground wire, we used bigger gauge wiring for it and grounded it directly to the chassis.
Old 09-07-2009, 09:21 AM
  #163
I actually am using the 240sx TPS, just not the pigtail. Is the black wire on the pigtail harness a ground? I've got one opened up so I'll check that out.
Old 05-22-2010, 09:13 AM
  #164
PooFlinginMonke's Avatar
I cut up my 280zx tps and just kept the flat mounting surface.
Then I tack welded the 240sx tps (actually M30 but same part number) right onto it since the throttle plate shaft is plenty long enough.
Been working great with a M30 sequential ecu for the last 20,000 miles.
PooFlinginMonke is offline
