blinker?
Old 04-23-2005 | 10:07 PM
81 Black L28E's Avatar
blinker?
Ok my blinkers stoped working ..i still have flashers/HAZARDS but know blinkers i checked the fuses and all of them were still golden.... what should i check next ?????is there a relay some where...
Old 04-24-2005 | 03:44 AM
It sounds like your flasher for the turn signals is out. It should be below the dash on the driver's side. It id either burnt out or a wire got disconnected. Hope this helps
Old 04-24-2005 | 10:52 AM
thanks player it does............. going out to check it right now
Old 04-24-2005 | 03:48 PM
Ok i couldnt find anything not hooked up under there so most likely the box went out......... there are two or three boxs under ther .......witch one is it
Old 04-24-2005 | 07:20 PM
Ooh I'm not exactly sure. It is going to be a metal round thing. When you tap it, sounds hollow kind of light a light bulb. It should be hooked close to the firewall. I can't quite remember. If you still can't find it. I will go look at my '81 for you!
Old 04-24-2005 | 11:30 PM
i will look i the moring drove around all day with out it and didnt get pulled over
Old 04-24-2005 | 11:37 PM
i will look in the moring drove around all day with out it and didnt get pulled over
Old 04-25-2005 | 03:03 PM
Dorifto's Avatar
Wow ... that's wicked. You posted twice in 7 minutes, the same message.
That's Golden Grahms.
oneadvent
05-28-2012 07:17 PM
Pipsqueak
05-24-2012 02:15 AM
falcon125
04-13-2009 02:15 PM
Whitesmoke
06-24-2006 03:41 PM
lightspeed
08-25-2004 04:33 PM
Quick Reply: blinker?
