Can I get this crank pulley to fit?!
Old 03-15-2012 | 02:22 AM
Trex's Avatar
Hi everyone. Long time, no see. I've just finally gotten around to replacing my old crankshaft pulley with the the one Nismopick was nice enough to hook me up with. I have the old pulley off but this other pulley has some sort of back plate which will hit the timing plate if I try to put it on. Is there a way to make this work? Have pics below.
Two pulleys side by side (new one on the left):
Two pulleys again flipped over so you can see the back plate:
The timing plate that the new pulley hits:
If you have any suggestions please let me know! Thanks in advance.
Old 03-15-2012 | 04:36 PM
Is that an S30 pulley?
Click: https://www.zdriver.com/forums/showt...&highlight=s30
I used it on my L28ET build.
Old 03-15-2012 | 06:30 PM
Trex's Avatar
Hi Nismo,
I assume you're asking about the pulley that was on there originally. It looks awfully similar to the pic of the s30 pulley you posted in your other thread however I definitely didn't do a swap like that, and I doubt the P/O did. I'm pretty sure it's stock given the position of that timing plate. This is a 79' 280zx we're dealing with here, and I saw a post in your thread that I'm thinking may be the issue:
i know that the early s130's had a diff crank pulley setup as well. i noticed one day when i had one of each on the bench, was kinda stunned
:/ Oh well looks like I may be forking out the cash for a performance pulley unless anyone else know's something about this.
Old 03-15-2012 | 06:48 PM
Does your 79 have manual steering (no power steering) or no a/c? If so, that's why.
Old 03-15-2012 | 09:05 PM
Trex's Avatar
Correct no P/S. Well looks like a performance pulley is in my future. Anyone else have experience with these? I'm currently looking at this one:
http://www.thezstore.com/page/TZS/PROD/PEM06/10-2139
If anyone has purchased this same one, is that $40 bolt and washer really needed or can I use the stock one? Or has anyone purchased a pulley from somewhere else that may be better and around the same price (or cheaper)?
Old 03-15-2012 | 09:38 PM
http://www.angelfire.com/extreme/280zxt/page22.html
Old 03-15-2012 | 10:20 PM
The pulleys are different from year to year. My 79 has the pulley with no backing whereas my 82 motors have the backing style. You just need a different timing marker.
Old 03-16-2012 | 10:57 PM
Trex's Avatar
So I can use this pulley and just swap out the timing marker with one from a later year? Or do I need to rig something up?
Old 03-26-2012 | 09:52 PM
Trex's Avatar
Well I've decided to just go with the aftermarket pulley and bolt/washer. I figure that any OE pulley is just going to end up doing the same thing anyway. When it gets here maybe I can finally get it out of the garage and post decent pics
Oh one other question. Is it a bad idea to use some thread-lock on the 5 screws that hold the radiator fan on?
Old 03-30-2012 | 12:35 AM
Trex's Avatar
New development!
Okay so I'm waiting for my new pulley in so I decided to do a little cleaning around the engine. I took some engine degreaser to a nasty oily/greasy spot on the timing cover next to where the pulley sits and what do I find:
That damn pulley carved a hole all the way through the timing cover! So now I'm wondering: what would make the pulley get close enough to cause that damage? So it looks like I'm gonna be in the market for a timing cover too. The only Z at my local pick n' pull is a 77 280z - that should be the exact same timing cover right? Thanks in advance for your help.
EDIT: Can I just JB Weld that shut? O.o
Old 03-30-2012 | 05:27 PM
mrprofile's Avatar
you should be able to tell pretty easily what part hit the timing cover, just look on the balancer and see what part of it is all scraped up, as for JB weld, you could try, but you wanna get a new one eventually.
Old 03-30-2012 | 10:05 PM
I just happen to have a 280z timing cover all packed up for shipping... previous offer bailed on me. $20 + shipping if that one at your junk yard is too much of a hassle.
Old 03-31-2012 | 02:08 PM
Trex's Avatar
I'm just going to try a lil JB Weld for now. I'm not really interested in pulling this water pump off (again) to change this out. The actual hole isn't very large so I think I can get away with it.
I do have another question though. How hard is putting this performance pulley on supposed to be? O.o the original one slid off pretty easily with a few whacks with the mallet. This one is a tighter fit and I'm trying to tighten it on but it feels like its taking a lot of torque to do so.
Old 03-31-2012 | 04:16 PM
Check the crank key.
Old 03-31-2012 | 06:13 PM
Trex's Avatar
Yep looks like the crank key got pushed back. I've read that boiling the pulley will make it easier to slide on to the crankshaft. Will that harm the pulley?
Old 03-31-2012 | 06:41 PM
No need...
Just use some bearing grease to hold the key level in the crank and slide on the pulley.
Old 04-01-2012 | 06:38 PM
Trex's Avatar
Alright. I'm going insane. I can't get this woodruff key to stay in place when I install the pulley. I can't just push the pulley on either - I have to use the bolt to pull it on to the crankshaft. So I don't know that it's screwed up until I've got the pulley half way on.
Old 04-01-2012 | 07:51 PM
Have you tried sliding it on w/o the key to see if it slides easily?
Old 04-01-2012 | 08:58 PM
Trex's Avatar
Yeah, it wont slide on easily even with the key removed. It's a really tight fit. I'm thinking I need to try heating it.
Old 04-01-2012 | 11:00 PM
Trex's Avatar
Alright! Well I heated the pulley with my heat gun and it slid on like butter! Then I was able to use the bolt to get it the rest of the way on. It definitely looks like it sits forward more but I think that's because it doesn't have a 1/3 of an inch of back plate sticking out and its not rubbing against the timing cover :P
Old 04-02-2012 | 11:15 AM
Trex's Avatar
Well I got it all put back together a timed last night. The old pulley had rubbed against that timing indicator plate too so I couldn't get a super precise timing done but I was able to eyeball it pretty damn close. Anyway its like a whole new car. I guess the bottom line on that powerforce pulley: a pain in the *** to install due to the tight fit but at half the price of a new OE style pulley - its worth it. Now let's just hope it stands the test of time. Thanks a lot for your help again!
Old 04-02-2012 | 08:05 PM
ZZzzz's Avatar
Trex!!! do you still have that pulley that Nismo gave you? it looks EXACTLY like mine, except that it isnt completely destroyed. none of my junkyards have that part, it would be a HUGE favor to me if i could get it. buy or trade, will pay for shipping, whatever you like. please let me know soon, as the weather is warming up and the car is looking sad in my garage.
also- i see a key setup on that one, but i dont feel the male side on my crankshaft spindle... could anyone get me a close up view of what it should look like? i really hope i dont need to buy a new crankshaft.
Old 04-02-2012 | 09:49 PM
Trex's Avatar
Hi Z. Let me make sure I have all the parts and I'll send you a PM :P Also there's a woodruff key that sits in a groove on the crankshaft. I snapped a bunch of pics while I was working on it lemme see if I happened to get a pic of that, and I'll upload it later tonight.
Old 04-02-2012 | 11:16 PM
Trex's Avatar
This is the best pic I have of the woodruff key slot on the crankshaft:
You can see where the woodruff key slides in.
goodoldZdays
FS: 300ZX (90-96)
03-12-2009 10:36 AM
sholez
10-07-2006 06:21 PM
HybridS130
02-06-2006 08:36 AM
81 Black L28E
10-04-2005 09:51 PM
lance75_280z
09-11-2003 06:28 PM
Quick Reply: Can I get this crank pulley to fit?!
