compressor bypass valve.
Old 09-30-2009 | 07:52 PM
captken's Avatar
hello,
from J pipe, how should I route the bypass? I am not using the aac. I think the J pipe went to it.
I have a bosche type bypass, like jim wolf sells.
help please.
got my panasports and re-11s. 225-50-16. tight fit on front.
pics later.
kenny.
Old 09-30-2009 | 08:04 PM
compressor bypass valve? do you mean the pop off valve?
Old 09-30-2009 | 08:28 PM
captken's Avatar
nope
pop off is different.
my car doesn't have a compressor bypass valve installed.
someone said it should go to pvc as a joke. Factory, it goes to the aac valve, I think.
Got rid of everything on the manifold, per fubar....to clean up the intake.
thanks, need to plumb up jpipe, gotta spark plug wedged in there for now.
kenny.
Old 09-30-2009 | 08:30 PM
^^^ That didn't really clarify anything... so, tell me, #1, 2, or 3? Sounds like you are talking about #1, but a bypass valve would either be the wastegate or blow off valve...
Old 09-30-2009 | 08:35 PM
captken's Avatar
turbo question
wastegate actuater plumbed to intake manifold instead of compressor outlet.
vaccum line to actuater collapses with the manifold vaccum.
turbo boost is limited to pop off valve on manifold. [I think]
question:
When boost happens, will it work to open up the collapsed vaccum line? I cannot tell blipping the throttle, standing next to car.
Actuater does not move, however, I know it's boosting.
Want to up the boost.
thanks in advance.
Old 09-30-2009 | 08:37 PM
I'm so ****ing confused right now, even obama is running circle around my intelligence...
Old 09-30-2009 | 08:45 PM
captken's Avatar
jpipe
guys, the stock jpipe has a hose fitting on top. From what Ive read from searching forums, this is the compressor bypass valve.
I cleaned up the intake manifold and don't have the aac valve, which I believe it was connected too.
I just need to know where to run a hose from the hose fitting on top of the jpipe to the intake.
sorry if im confusing yall.
The j pipe runs from the compressor housing to the 240sx throttle body, it has a wrinkle black paint finish to it, shaped like...well...a..."J"
I don't see it in your excellent pics nismo.
kenny.
question:
thanks in advance.
Merged threads... no need for 2 threads when you already have a new thread.
Answer (in another question)... have you tried getting vacuum likes that won't collapse?
Old 09-30-2009 | 08:46 PM
I just need to know where to run a hose from the hose fitting on top of the jpipe.
kenny.
Apparently Jim Bean is present and not captken tonight.
Pick #1 #2 or #3 from that picture I posted.
Old 09-30-2009 | 08:59 PM
captken's Avatar
yes they are nissan.
Niku-Sama's Avatar
eff good grammar
wrx/sti's use by pass valves, check with the subaru peoples.
dont ask me i have a turboed subaru but i no nothing about how the turbo works in it other than it spins pushing air into it....some how...its kinda funky
Old 09-30-2009 | 09:02 PM
captken's Avatar
jim bean
Is not present.
I think, from your pic, #1. However, where is the Jpipe? I cannot tell.
sorry, kenny.
Old 09-30-2009 | 09:06 PM
I'm not sure why you are making a big deal about the j-pipe, but it wasn't installed when I took that pic. Here's a "complete" one for you:
Old 09-30-2009 | 09:12 PM
captken's Avatar
post a picture
I'll post a picture tomorrow.
Yes, the 280zx turbo has a compressor bypass, it went to the aac valve. I cleaned up the intake manifold and now the jpipe fitting has no place to go....!
phone camera picture of car.
kenny
Old 09-30-2009 | 09:16 PM
man... it's like pulling teeth to get anywhere in this thread....
Old 09-30-2009 | 09:17 PM
captken's Avatar
I see
So I have to plumb it back to the intake manifold. Should I reinstall the aac valve and do it your way, or will the avaliable vaccum ports support the volume of air?
kenny.
Old 09-30-2009 | 09:19 PM
captken's Avatar
hey
and with the help of my friends, I'm learning, thanks, kenny.
Old 10-02-2009 | 01:04 AM
lifegrddude's Avatar
Externally Wastegated
If I read your first post right, you can use the nipple on the J-pipe for the bottom of the bosch bypass valve, and use the recirc part to vent back into a tube before the compressor. It's not pretty, but it will work. Otherwise, I'm misreading what you're trying to say. The Bosch bypass valve is only good to about 14 psi before it leaks btw. The Porsche style ones can handle a bit more boost, but not much.
Old 10-04-2009 | 09:00 PM
captken's Avatar
thank you very much.
I installed the bosche bypass valve just off the jpipe. I am currently venting to atmosphere.
Satisfying phooshe...! sound everytime I lift off throttle, it operates everytime I lift off throttle, even a little bit, you hear it, so I know the compressor is spinning freely on partial and closed throttle.
I will plumb it up to intake later.
Problem is, 2 turbo cars and one complete engine in parts! No static model for me to reference.
thanks for your reply,
kenny.
Old 10-04-2009 | 09:27 PM
Sweets's Avatar
Usedta be Justin260z
I lol'd.
Is is plastic? Most of those plastic bypass valves leak boost.
Old 10-04-2009 | 10:34 PM
FubarI33t's Avatar
all that money into that cat. just get a good aftermarket release
Old 10-05-2009 | 08:25 PM
captken's Avatar
we did the intake maniflold cleanup sticky.
you created and was posted as a sticky, Unfortunately, I think it does not apply to the turbo car.
kenny.
Old 10-05-2009 | 08:31 PM
captken's Avatar
advise
You helped get me to where I am at today, learning about, and enjoying my car, cheers, kenny.
shangoZ
08-19-2012 09:53 AM
domsgarage
13
05-14-2012 08:16 PM
captken
08-20-2009 12:11 AM
allmotor300z
04-22-2005 10:28 PM
haktmal
04-20-2003 07:59 PM
