Condenser
Old 05-19-2010 | 12:35 PM
83Turbo's Avatar
Question Condenser
Where can I order a new Condenser that is on the side of the bracket that holds the ignition coil? The condenser is a SHIZUKI 250-0.47
Old 05-19-2010 | 01:26 PM
Welcome to ZDriver!
If this is for a 280zx TURBO (you didn't mention the model... I'm going by your name that you have a turbo), it's actually an ignitor, not condenser (the black square box w/ two spade pins). You can buy it through Nissan, or a junk yard.
If you are talking about the one wire cylinder condenser that runs to the bottom of the distributor, that's an RF resistor, and can also be bought through Nissan or a junk yard, though it's not necessary to have it installed.
Old 05-19-2010 | 02:54 PM
83Turbo's Avatar
Sorry, I have a 1983 Datsun 280zx Turbo, 5 speed. The deal im talking about is placed on the right side of the Distributor Transistor Unit. If it's the RF Resistor, i didnt find any at Nissan. I would also think you would have to have it installed so the distributor wouldn't send to much power to the ignition coil and fry it
Old 05-19-2010 | 03:22 PM
Do you have a picture?
Because I'm not sure what you mean by the "deal" that's placed on the right side of the transistor... There's only 3 things: Coil, Ignitor transistor on the side of the coil bracket, and the insignificant RF cylinder (not pictured below).
This is a scan from the FSM, which part are you talking about?
Old 05-19-2010 | 06:17 PM
83Turbo's Avatar
The deal I'm talking about is in the Red Oval
Old 05-19-2010 | 06:23 PM
Yep, that's the RF resistor. The car will run fine w/o it. And you apparently still have it, so why do you need to replace it?
Old 05-19-2010 | 06:27 PM
83Turbo's Avatar
One of the wires are cut half way threw, and im having to replace the Ignition Coil and the Distributor Transistor Unit anyways.
Old 05-19-2010 | 06:37 PM
Wire strippers, soldering gun, and some heat shrink... a lot cheaper and quicker.
TigroGT
10-20-2014 07:33 PM
Spurs212095
06-05-2012 11:02 AM
