Crane cams ignition install
Sorry if this is considered a double post but ive been trying to put this thing in and ive been goin by the hitachi distributor instructions because they make the most sense from what i see in front of me but now im stumped.it says to put the optical trigger output wires through the grommet that the pick up wires went through but on my 80' 280zx the pick up wires go into the ignition module right?So can i completely take the ignition module off of my distributor and just run the wires through the hole where it was
________
Love quotes dicussion
________
ok sorry i figured out the answer to that question but now do i leave the original wires plugged to the coil along with the new wires coming from the crane ignition module or do i tape them off.My guess would be combine all because dont the wires come from the batter to power the coil?
________
LianaXSexy
________
LianaXSexy
Please tell me someone here knows the answer.Everything is put in and ready to go i just need to know about the coil wires so i can get back on the road
________
Creampie Tube
________
Creampie Tube
If I remember correctly dude It says to tape it off. I have the xr700 module but I haven't put it in yet. The coil wire it says you need a spiro pro, pretty much one of the performance plug wires. There's a chance you can get it from your local auto zone. Was it easy to install the electronic ignition? Did you use the stock coil or one of the crane cams ones?
i havent got to use it yet.It says to tape off the wires from the module but now i dont know how to hook up the coil wires becasue the xr-700 has coil leads from it but do i combine those with the wires already coming from my car to the coil?
________
hairy Cams
________
hairy Cams
I know there are the wires for the optical trigger. Aren't the other one's for the power and grounds? I have the ps-91 coil and it says I have to have a chrysler style ballast resistor but I'm gonna try to run it through the stock one.
are you leaving the stock cables that already went to your coil before you got the xr-700 on along with the cables from the xr-700.Or are you taping off the original negative
________
GANG BANG COLLEGE
________
GANG BANG COLLEGE
I'm connecting them to the coil I think. I haven't gone through and tried to install it yet but I'm pretty sure that's what's going on. There are two prongs for the ground and positive then the stud for the coil wire on my ps-91 coil.
vtdds71
06-30-2013 06:40 PM
micjman
03-25-2011 02:31 PM
RunninOnEmpty
09-07-2003 10:43 AM
