D2 Coilovers
Now I see why I've never heard of them. Have you looked to see if they make a set for your car?
If you drive a Z car older than 1990 they don't have anything for you.
If you have a 2nd generation 300ZX then you're in business.
I would check reviews of their products before buying though.
S13 Megan Street coilovers are probably your best bet. Great performing coil over that is fairly straight forward to modify to fit the S130. The rears bolt directly in and you just need to mod a set of front spindles for the front either S130 to S13 or vice versa. Lots of write ups on the swap....
bumping
they aren't great they are entry level
the valving isn't fantastic you are gonna have to play around with it if you decide to go with them
they are ksports painted purple
https://www.google.com/search?hl=en&...=wf&authuser=0
Yes you are better off doing megans from the s13
ground control from what I could find only has coils for the front
ground control from what I could find only has coils for the front[/QUOTE]
http://www.ebay.com/itm/Ksport-GT-Pr...item2a07eecfd0
2 front+ 2 rear
2 front+ 2 rear
zyko300zx
03-30-2004 07:06 PM
