dash lights quit working
i bought an 83 datsun 280zx a couple weeks back and the dash lights would flicker with the rpm, when i replaced the battery they quit working all together. all the warning lights work and the pre flight check list thing. i noticed that when im turning my key off they will flash for just a second. i just replaced my battery ground cable but it didnt help. any insight into what may be going on would be greatly appreciated.
If this isn't something that you end up fixing right away just make sure its only your dash lights going out. When I was DDing my slicktop (it may still do it who knows I've only had it running a few weeks now) the dash lights would randomly go out, sometimes just for a second or two sometimes for two or three days. After a few instances I found out that the tail lights would go out at the same time. That's a great way to get your car towed
ill check that out. its funny you said that because my warning light came on saying i had no brake lights even though ido, it comes and goes which is very strange. theres two wires on the side of my ignition and one is not attatched i tried several combo's while it was running but none changed anything i could see
so i got a multimeter and on the brown connector in the footwell im getting nothing except the far right has 1.24 can i just run a power wire right to the connector or does it go threw a fuze somewhere?
Scarecrowtim
08-26-2019 02:48 PM
todd5854
03-17-2014 10:52 AM
kr11zzz31
09-08-2011 07:39 PM
