Difference between 5-speed and auto engine?
My ZX is a 83 NA 5-speed. Is there a different engine for the 5 speed and the automatic transmission?
I found a rebuilt '83 engine in a wrecked car, but the tranny hooked to it is an auto. Does this make a difference? If so, can some adjustments or parts be switched to make this work?
I know with my wife's miata i was told what to swap over to be able to mount her auto tranny on engine that came with a 5-speed. It works fine and seems to have more power than the old engine that came in the car.
thanks for any advice on this.
Theres I think 3 diffrences.
You need to remove the Automatic pilot bushing from the crank and install a manual one.
Theres the vacuum port for the automatic trans kickdown. It can be capped.
And lastly I think the distributor had different mechanical advance in it.
deadly300z
02-05-2013 12:54 PM
