dump sacked
Old 04-03-2006 | 12:38 PM
81 Black L28E's Avatar
dump sacked
Iam sick of my 4x4 ....so...I have a extra set of springs from the gold peice of crap out back ...Me and grey_ae86 are going to cut the spring from the gold car and put them on The Black.....I will post pics and let you all know how it turns out ....We are just going to take a coil or two out of each strut and put the struts and everything from the gold car to my car....That way if i dont like how it rides or we mess a coil up i can put my stock ones back on ....
I want this black bitch to sit on the ground ....Dump sack time
Old 04-03-2006 | 01:02 PM
If they're the same diameter... go for it. I've used springs from a Mercedes 300D on my Z before. Stiff as hell & got rid of the squat.... Tho it felt like I was driving on a trampoline.
Old 04-03-2006 | 05:16 PM
i used chevy van spring, progressive no less. the need to be trimmed though.
Old 04-03-2006 | 07:27 PM
ok its done check out the pics ; ) ....dumped sacked ..
befor
after
the work
i think it turned out good ..the ride is a little bouncey butt nothing bad ...i want to take one more coil out of the front ....well mabe tomarrow ..
Old 04-03-2006 | 07:33 PM
nice bro! looks like a good ride height... hopefully you don't drag going over a speedbump or driveway.
Old 04-03-2006 | 10:34 PM
Gray and I cut one more coil out off the front ...Just befor we ran out of light ..I will post more pics of it in the moring when i get some more light ...Now the front is sitting on the ground!!!.i didnt like it befor it just wasnt low eff in the front but now its slam tucken .I took her out for a little night run and man o man kick out city ..it scared the **** out of me ...Its stiff as **** you when you push on it there is little to know bounce ..I love the feel of her now ..I dont have to go near as fast into the corner to make it break out ...It pushes power to the wheels so much better.....Iam stoked ..There is little to no under streer when you whip it around in a parking lot or corner kick out ......The front pushes though and not away from the corner ..Now that i have pulled it apart and know how it all works under there i realy want coil overs but owell ..I will live with this untell i get money for the goods....MORE PICS TOMARROW FOR SURE
Old 04-04-2006 | 08:47 AM
that is slammed! wow....
and your easy kick out in the rear might possibly be due to toe out that happens when lowering the rear of the 280ZX. Drifters do that on purpose so the rear can loose traction easier. Just wait till you take it up over 60... the rear will wander. Mine does just a little from the springs sagging about and inch.
Now you need some 15x8 zero offset wheels, yo!
Old 04-04-2006 | 10:02 AM
Yikes! Wander as in "lose control" or "easy to kick out" ?
Old 04-04-2006 | 11:18 AM
camber is good zcar food ....iam out to go drive this bitch and take a few more pics...when i looked at her this moring i was like ............dam ....
how low can you go ....
Old 04-04-2006 | 12:00 PM
lww's Avatar
lww
Head Muckraker
Some camber and all the caster you can get are good on a street car. Toe out is BAD! Especially rear toe out.
No regularly driven street car should have any toe out on the rear. At highway speeds it can make the back end very squirrelly.
If there are any ruts or irregularities in the road from heavy traffic the back end will tend to 'climb' up the sides of the ruts and when you correct it, it'll swap back to the other side and climb up that rut. It can be very entertaining...
On my race car, I had 1/8" toe out on the rear and 1/4" toe out on the front. This helps the car turn in more responsively, but can make driving on the street down right dangerous. Remember, race tracks tend to be much better maintained than your local municipal streets.
Old 04-04-2006 | 12:04 PM
I get a very slight rear pull now and then on the freeway like you mentioned and my springs are sagging so the back is lowered. That's common on the ZX if you don't do something to correct the toe.
I know its not just the road because my truck with a rear solid axel drives very straight on the same freeway.
Old 04-04-2006 | 01:28 PM
jfairladyz's Avatar
Toe is good for GT4. Bad for street car. My ZX2 had some serious toe issues to due to some rear end damage from an unfortunate jumping incident and that car was just down right scary to drive on anything but dry smooth roads. If it started raining or snowing it was over. That was spun off the road so many times from poor weather. That left me scarred for a while after driving it that way for so long.
Old 04-04-2006 | 02:36 PM
i love the feeling of it .....it was a kick out beast ,like that last night in the wet... but today in the dry it was corner king all the way ...i snaped a few shots in the drive way ..the extra coil cut made the front look so much better ...handling wize it stiff and ruff as ****...but i like the feel ..i just have to be very carefull in and out of parking lots and speed bummps ..my header is the lowest point......
so i really got to watch it ....
anyway it looks tuff and drives savagely ...coil overs in the future...and new bushings ...aluminum rate. or elc. fan for sure i want to keep this motor cold come summer time .....
Old 04-04-2006 | 05:21 PM
jfairladyz's Avatar
It definitely looks good. Thats for sure.
Old 04-04-2006 | 05:58 PM
HybridS130's Avatar
1.) I had the same muffler as you on my 1980 Z
2.) Looks great, Im sure the ride is interesting as well
3.) Looks like you skate the **** out of that little ledge
Old 04-04-2006 | 07:14 PM
i bought my friends improperly lowered z with camber issues, it was bad to drive over 55 mph. if you can do the adjustments, id do them to save tires and the unwanted spin into oncoming traffic my friend did. otherwise it looks great.
Old 04-04-2006 | 08:05 PM
1 ...tight Bangin
2 ...realy It Is Fun To Kick Out
3...yes I Do
Old 04-04-2006 | 09:45 PM
Skully's Avatar
yeah looks good...
are you wearing safety goggle when you grind (should wear a FACE shield! trust me) i was tempted to do this too but the car drove like **** on the old springs that were cutt so i replaced with new ones and its nice...
Old 04-05-2006 | 12:43 AM
My girl is very picky about how a car rides ..She rode in it tonight and she loved it ..She was like , i thought it would be all bouncy but its realy stiff ...I dont like the ride hight offerd on lowerd springs for zx 1.5 inches is a joke .So i think iam going to get stiffer lowering springs and then cut a coil or to OFF of them..... not right now but someday ..i wish i could cut and reweld the perch on the struts ..but we CANT all have it eazy like the ae86 owners hmmhmhmh Gray....
if freaken coil overs wheren't so taxed then ...well you all know ahhahah .anyway iam stoked out she is alot more fun to drive and iam getting alot more used to going over bummpyes and parking lot in and outs ....kick out how ever are bigger scaryer but more controlded and eazyer push though ...all in all another great cheap mod that any back yard drifter needs to try at least once .....
Old 04-05-2006 | 10:39 AM
lww's Avatar
lww
Head Muckraker
Hey, as long as your girl likes the ride stiff... Although, mine prefers it bouncy...
Old 04-05-2006 | 12:08 PM
Carl's Z's Avatar
Skully, every time you post, all I can keep my eyes on is your avatar, and those canook hooters. GEEZ!!
Old 04-05-2006 | 01:10 PM
wow, R, that is very low. You need some bigger wheels to fill those fenders! That would look goooooood.
Old 04-05-2006 | 05:50 PM
i like canuck hooters
Old 04-05-2006 | 07:30 PM
we took a little road trip to port townsend ...its way up north in washington for thoughs of you that didnt know ..they got a new skate park and i wanted to check it out ...i also took some time and snaped a few z pics along the way hope you all like them ...iam so stoked on the ride i let the girl drive her on the way back and she said that it drives alot better ...
and yes iww she likes it stiff and bouncy ..lolololol
and one kick flip back side tail
Old 04-05-2006 | 07:47 PM
Cruzin w/ the T's off... that is the life! It's the shiznit biznitch!
