electric window problems
Old 06-29-2009 | 05:41 PM
Timc.king01's Avatar
I was wondering if anyone out there knew what the problem could be with my windows i got the car about a month ago and both windows for some reason do not work anyone have any answers thanks
Old 06-29-2009 | 07:41 PM
njgheewala's Avatar
Dunkin' Donutz
You gotta give more info on this...what is it doing,? do you hear the motor? You can also turn the light in the dome and see if it dim when you press the button.
Old 06-30-2009 | 08:20 AM
kittyz's Avatar
fuses. try the basics first.
Old 07-03-2009 | 09:27 PM
rogerz's Avatar
Grumpy & Helpful
as above probably not getting power. the door switches to control the window may be bad but probably not both of them so I would suspect primary power loss. pull the door panel and make sure everything is not rusted together. after you check the fuse see if getting power to the door switch with a vom. fuse box itself is known to go bad so you might inspect that.
lts70
12-22-2010 03:04 PM
Niku-Sama
09-28-2008 01:32 PM
skupy
11-14-2005 02:42 PM
kraftor80
11-02-2004 10:23 AM
Las VegaZ
08-31-2004 05:00 AM
Quick Reply: electric window problems
