Electrical problem in brake circuit.
Hey, new to the forums and Z car ownership! I have a 79 280zx N/t and I have a small problem that is draining my battery. Whenever I press my brake pedal all of my lights dim ,the radio shuts off, and the dash lights come on. Thinking it might be a bad ground so I'm going to tackle it with a volt meter tomorrow but just checking on here to see if anyone else has had a similar problem and found a simple fix.
Yeah I thought that too, I had a tail light out and cracked plastic on the 79 rear lights so I swapped to fully working 82 tail lights and the problem didn't go away. I'm thinking maybe one of the wires rubbed the insulation off and is grounding out but I don't think the tail lights would work if that was the case.
It died out, wouldn't start up. A couple days ago I got the battery test done after the car wouldn't start and it tested bad. So I went and got a new battery. Worked fine for about 3 days and then died again. I doubt it's the problem though since the car had the same problems before and after the new battery.
rigez
01-08-2002 08:12 PM
