electronic instrament panel not working in 83 280zx
Guest
Posts: n/a
hi...friends 83 280zx has a digital instrament panel (speed, odometer, fuel etc) which goes on and off while driving. when the car ignition is set to acc or on, it works, however, once driving, the majority of the time it does not...replaced the entire instrament panel, same problem...any suggestions or something we are not checking? thanks
or the ground.... if you can find one or more of the ground wires coming from the cluster, try to run additional ground wires off of that (as close to the instruments as possible) to the dash frame. Maybe that's all you'll need.
ColeParker
10-09-2014 12:56 PM
FricFrac
07-13-2012 12:45 PM
