engine ticking noise
Old 01-07-2009, 02:56 PM
scorpionp54's Avatar
my engine started making a ticking noise louder then usual, i think its the injectors because when i do the stethoscope test with a screwdriver i can here the ticking and also i can here it threw the fuel rail. when i unplug an injector 1 at a time the noise slightly goes away. is there another easy way to test the injectors?
scorpionp54 is offline
Old 01-07-2009, 03:03 PM
The injectors are supposed to tick.
NismoPick is offline
Old 01-07-2009, 03:06 PM
they got louder then normal. i tried to get a video but my camera wasnt working i'll try to get it soon
Old 01-07-2009, 03:32 PM
do you have hydraulic lifters? they may be on there way out and causing some extra clatter.
SHADY280 is offline
Old 01-07-2009, 03:38 PM
if hydraulic lifters are what came in a 82 na stock, i havent looked up what i have
Old 01-07-2009, 04:13 PM
i believe 83 was the first hyd. lifter year, but ive know to miss by a bit sometimes. if the car still runs fine, maybe your just hearing better!
SHADY280 is offline
Old 01-07-2009, 04:20 PM
im only 19, and i dont remember having but im going to go look up that thread on hybridz on the noisy lifters.
Old 01-07-2009, 04:27 PM
NisTuner
duowing's Avatar
do the solid lifters get noisier when they're in need of adjustment?
duowing is offline
Old 01-07-2009, 04:57 PM
i look at my head and i saw a p79 above where the number 2 spark plug
Old 01-07-2009, 05:11 PM
Yes... but they are easy to adjust.
Yeah, you don't have hydraulic lifters.
Old 01-07-2009, 05:18 PM
so would they make ticking noises from old oil or are they just out of adjustment
Old 01-07-2009, 05:19 PM
and i adjusted them a few months ago and they were fine i'll change my oil first then if they are still ticking i'll look to check their adjustment
Old 01-07-2009, 06:41 PM
You can check the gap right now w/ feeler gauges... then you'll know if they are making the noise / needing adjustment.
Old 01-07-2009, 06:49 PM
i would but all my tool are at my parents house and my at my apartment 100 miles away, i need to do an oil change anyways
Old 01-07-2009, 07:54 PM
speed280zx's Avatar
Hey nismo do you know how many thousandths they are to be set to? I might be needing to adjust mine...
speed280zx is offline
Old 01-07-2009, 07:57 PM
i beleave it .010 intake and .012 exhaust for the hot. not shure what it is on cold
Old 01-07-2009, 08:00 PM
Indeed. Cold is:
.007in / .17mm intake / .009in / .24mm exhaust Page 26 of the Haynes manual.
Old 01-07-2009, 08:01 PM
ok cool it would be easier cold then when i did it hot
Old 01-07-2009, 08:05 PM
I used to do a "mad dash" trying to adjust them hot. Then one time I loosened them all at the beginning, then adjusted them one by one. That gave me more time.
Old 01-07-2009, 08:08 PM
speed280zx's Avatar
Sweetness.. Yeah still need to order one of those.. !
is it better to do it hot or cold
Old 01-07-2009, 08:17 PM
Ideally you want to adjust them hot, because metal expands when hot (aka running temp) so the adjustments will be more accurate.
Old 01-07-2009, 08:27 PM
ok i'll do it hot and burn my fingers
Old 01-08-2009, 05:52 PM
just another quick question, about what is the average life spand on the fuel injectors, i have 67000 miles on my engine
Old 01-08-2009, 06:27 PM
It depends on how well they have been treated... but they should last as long as the motor.
Quick Reply: engine ticking noise
