Exhaust Manifold
Old 03-17-2011 | 10:31 AM
BackHouseZ's Avatar
Exhaust Manifold
Does any one know where i can get a new exhaust manifold for my 83 turbo?
I called Nissan Parts and they want 330 for the part, must be ordered.
I took it by a shop and they quoted 800 parts and labor...
since i have a broken stud the have to take the head off and drill out
bigger studs to make it stronger.
i was also told that my manifold is warped and i should not get a used one because it may be warped already.
OK I JUST GOT OFF THE PHONE WITH COURTESY NISSAN AND THE SAID NO ONE IN THE COUNTRY HAS IT AND IF THEY WERE TO ORDER IT FROM JAPAN.
WHO KNOWS WHEN IT COULD GET HERE..BECAUSE OF THE DISASTER!!! BUT IT COST $243 PLUS 40 Shipping
Nissan plant closed untill march 20th in japan!! but who knows what could happen.
any thoughts?
Old 03-17-2011 | 11:33 AM
PurePontiacKid's Avatar
i felld offa mai trike
get your stock one surfaced
Old 03-17-2011 | 12:47 PM
I guarantee (99%) that it's not warped... the shop is only saying that because it probably burnt through the gasket, ACTUALLY DUE TO THE BROKEN STUD. This is a common problem on the L28's... and even if it actually was warped, do like PontiacKid just said and get it surfaced for $20 at a local machine shop.
Also... you can find turbo manifolds all over... you don't have to buy a brand new one.
Looky: http://cgi.ebay.com/ebaymotors/Datsu...Q5fAccessories
Old 03-17-2011 | 01:04 PM
BackHouseZ's Avatar
well that sounds a lot better, than what the shop said..
I will get a second opinion from another shop.
Old 03-17-2011 | 04:33 PM
Or..... you could save yourself a lot of time, and money, and just stick a straight edge or level across the face the manifold... and take a look yourself. Use some feeler gauges to check if there are any high / low spots. No need to draw things out here...
Old 03-26-2011 | 02:19 AM
acleveland38's Avatar
and again i have a manifold ill sell you.... id be a pretty sweet deal with those injectors.. eh eh
stiletto660
08-21-2014 01:53 PM
stiletto660
08-11-2014 04:09 PM
noelawinslow
05-21-2013 01:17 AM
duckyz
03-03-2012 11:10 PM
h8raidweed
05-13-2003 06:22 PM
Quick Reply: Exhaust Manifold
