F**king Seriously!?
#28
Alright, I got the new gaskets on, WITH copper seal spray stuff, Put my dizzy shaft in correctly, primed the oil pump, Red siliconed the **** out of the oil pan, Even pressed in a new seal for the crankshaft pulley (hey it came with one so why not?) And put a new Tstat in and sealed that up with red silicone as well. No new water pump tho. but I might go get my rad dunked. idk.
#29
IDK about silicone only for a T-stat. Also, the gasket is a fairly universal design for the thermostat house cover. Napa def has them since I got one 2 weeks ago. Unless you mean the gasket where the thermostat housing mounts to the head itself, in that case, idk WTF you took that off for, but I made one from gasket material.
#30
If it leaks I'll goto napa and and see if they can get me one, last time I tried to get a gasket set they wanted to charge me $15 in freight on a $9 kit. And yes I only took the top half off lol
#32
Relax man, and take a breather. Seriously, take a break. It wasn't easy for me either. And it was my first time this past November. I actually put it together the first time. And ended being off one tooth. Talk about frustrating, I was so aggravated. I decided to calm down, and think it through. And I took it all back apart again. It was a pain to get the timing cover on, while keeping the dizzy and oil pump aligned. Believe me bro', I feel your pain. You can do it, I got faith in you. Just have some faith in yourself too. We are here for you.
#33
Bleh I feel stupid for that last post now that I've calmed down. I'm just still in awe that the EGR plate that was welded on blew off!
Edit: Well I WAS going to just JB weld the plate back on by now I'm paranoid that it wont seal or a chuck a JB weld will run down inside then break off when its hardened and destroy my motor. Guess I just better find a new intake manifold and gasket and injector o rings and bleh.
#38
The Z is fixed, for now anyways lol And as far as I can tell its not leaking anywhere! (sept for the damn rear main) Note to self, ALWAYS buy felpro gasket kits, not the cheaper kit.
Now to replace the (list goes on longer then the post limit allows)
